SOURCE: Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
SOURCE: Ricoh FAX5000L - Check: Network Error! [10-40]
Usually this means it was previous;y hooked up to a network, or the network settings have changed and they are mismatched. Do you use it as a printer? If not, in the user settings, (I'm not exactly sure where, but you can download a manual at ricoh.com) just set all the network settings to 0's - for example Ip address, gateway, etc. Otherwise set them correctly in order to print.
SOURCE: ricoh 2050l confirmation reports
It's more complicated than it needs to be. You'll have to refer to the user manual under 'user parameters'. It's to difficult to explain here. But I can tell you that it is switch '3'......Bit '0' that needs to be changed. manual is here if you need it:
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
* select "Fax 2000L" from the drop down menu (it's the same as yours"
*please rate me :)
