I received my Axim today with the screen protectors and can't find any instructions on how to apply them. Any ideas?
They come as a thin piece of plastic attached to a stiffer piece of plastic. There is a small tab extending from the corner of the thin plastic. It also appears that the protector may extend under the case at the top and bottom of the screen.
They help by keeping the stylus from permanantly scratching the glass screen (a costly repair). It is most needed for those that use the unit for writing vs. tapping. Areas like the scrollbar in IE and where you commonly write will be the most used therefore most likely to get scratched up. It will be very annoying once it gets scratched and will stand out like a brick on your nose.
My Axim X51 will not allow me to download a library program that meets the specs. It(the...
(More)
My Axim X51 will not allow me to download a library program that meets the specs. It(the axim)message says its not a program made for PDa but it is. Whats up with this?
What do i do if my palm freezes? I tried to go into notepad and now can't get past a blank white...
(More)
What do i do if my palm freezes? I tried to go into notepad and now can't get past a blank white screen.
i can't stard my pocket PC .when I press the boutton
power this message s' post on L screen...
(More)
power this message s' post on L screen (maitenez the stylet pressed on
the target with each position on screen.la target will continue to
move jusqu' has what l' alignment is correct) .i make all its stages
but it does not start, so help
me and thank you .
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
