Question about RCA D52W19 52" Rear Projection Television
Rca parts hi! thx for the helpful info... did you get a chance to replace the parts?
Yes and unfortunatly it failed taking out all the parts again. I'm back to square 1 trying to figure out the fix for this. RCA recommonds you replace the deflection board which is on international backorder and doesnt appear to be available anytime soon. I need to get back into the set and poke around with a multimeter and osilliscope see if I can't pinpoint whats causing it to blow parts back out.
Posted on Sep 03, 2008
Hi. I have a GE range model CGS985SET2SS. I need a new valve assembly due to over tightening the appliance connector hose. I see conflicting info on the web. Is WB19K10043 the correct part?
Hello. The valve, part designation 1600 on the exploded parts diagram is called a "lockout valve" and has the part number WB19K10059. It may cross-reference to another part number--that is common. The control valve, part designation 214 on the diagram is part number WB19K10079. I hope I helped you!
Aug 03, 2015 | GE Kitchen Ranges
Keeps blowing fuses i checked all the solder points and they are fine help me fix the problem plz
Hi spikehair200,
Make sure that you replaced the fuse with exact ratings. Low ampere ratings will not handle current as what the original fuse installed. If still fuse keeps blowing after replacing with the same rating, this is an indication that you have a short on the power supply section. It can't be fixed by replacing the fuse alone. Short usually near the AC line where parts like the following are present.
  1. Power Cord - even very low of chances but still to be check.
  2. Posistor and degaussing - even very low of chances but still to be check.
  3. Rectifier diode
  4. Main filter electrolytic capacitor
  5. Voltage regulator I.C.
This is the common parts that might be shorted and made the fuse blew. You may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don
Mar 08, 2011 | RCA G27649 27" TV
How can i connect a secuity camera that has a yellow and white rca jacks to my comp
hi rja8410m
You need a video card that is capable of outputting rca signals.
Also check your video card slot if its agp or pci-express
Hopefully it helps
Thx
Banaple
Sep 03, 2010 | eMachines EL133105 Desktop Computer with...
RCA FLYBACK
Hello: The first thing is optaining the exact replacement part. Next there are approixmately 12 pins on the bottom of the deflection board where the part is located that need to be unsoldered there is a slightly thick red wire coming from the top of it that goes into the splitter block and a thin red one that goes to the focus Block, each need to be removed. To get to the focus block the lower front cover of your television needs to be removed Reverse the procedure to install the flyback transformer. You may want to purchase a soldering iron and some solder wick, commonly known as desoldering braid from radio shack.
Please leave comment...Thx
Aug 30, 2009 | RCA HD56W66 56" HDTV
RCA HD50LPW42 Shuts Down after 30 mins
Well it seems you may have an issue with your ballast that it's losing the energy it used to have , but we would need more info for a more accurate answer about this, discountdashmerchantdotcom
Jul 24, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
ID component
If it is a high wattage resistor and it is burned, chances are you have more than that wrong with the set. Resistors rarely fail unless something else shorts and draws excessive current through it.
Feb 28, 2008 | RCA F36650 36" TV
Adjust picture tubes
If all 3 crt's were replaced it sounds like something was not reassembled properly. There is a chance that the mech. focus on the crt lens need to be adjusted, or the mirror is not in the right position or it is possible that the convergence is not properly aligned. If you can send me a digital picture to: lap9728@msn.com I can probably give you more info.
Feb 12, 2008 | Televison & Video
RCA D52W20 Turns off after a short while
1)Solder any / all bad connects on main/power board +
2) Pull little sister board loosely mounted on one connector =
solder connector pins = re-assemble..............T.
Nov 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
