Question about Acer Aspire T135 PC Desktop
Pc problem nothing will open with my pc, it comes up with windows cannot open this file and needs to know which program created it. I cannot download anything. I need to know how to wipe everything off because I have an orginal acer backup disc that will reinstall xp, can you help please
  • Roberta Smith
    Roberta Smith May 11, 2010
    what is the file name you are trying to open ?
    Robert
    Brigadier General:
  • 5,158 Answers
Actually if you wish to wipe everything... just boot to the dvd/cd rom and the disks do the rest
Posted on Sep 02, 2008
I downloaded 2 things and I can,t find them in my download folder where will I find them
Not sure which version of windows you have. Click on the start button or the apps button on Win 10. Open files and search buy the name you saved the as. Or take another look in your downloads folder and click on the date column to sort buy download date and see what comes up for the day you saved them. Thx
Jul 28, 2016 | HP Computers & Internet
Tip
How can you crate setup file or .exe using QT platform
We are developing software but we are unable to run in others PC/Computer. As we know that QT is Platform Independent and Open source Software, which is use Nokia to develop Mobile Application.
Needs:
  • Qt
  • Setup creator
  • libgcc_s_dw2-1.dll
  • mingwm10.dll
  • QtGuid4.dll
  • QtCored4.dll
Procedure:
  • When you start a project then automatically qt creates 2 folders within main Directory. One is "Debug" and another is "release".
  • If we are want to run application in other PC then we need ".dll" files and combined them.
  • Open My Computer and go to the "Installation Drive" where QT is installed.
  • Find out the Main Directory of the QT. If you install in "c:" then go to the c drive and open "qt" folder and get a directory name as "2010.01"
  • When you open "2010.01", then you can see another directory as "qt" open it.
  • You click on Search option from the "Standard Button" bar and type the libgcc_s_dw2-1.dll file and search it. When you find it copy the file and paste into your Project Directory's "Debug" folder. Do same things for another three ".dll" files.
  • After that you can run your application by the .exe file. Does not need to open Qt and open your project then run.
  • Now you can simply copy the project Directory and paste into other PC and open Directory and run it.
  • Or you can create a shortcut on the desktop as others software. From where you can run it by Click.
Deploy and Packaging:
If you want to create a setup file as other software, need to install it. Then -
  • First download a file "icinst", it's free. After that install it.
  • After that open it from start programs and windows will be come where you select your Project Directory and do "Next".
  • You can create a License Agreement as others software.
  • Do as per the given Instruction.
Note: Before create a setup file you must be collect all dll files and paste in "debug" folder
Imon Saha
on May 16, 2011 | Computers & Internet
Tip
Create your own autorun CD or DVD
It is easy to create an autorun CD or DVD for Windows and all it takes are a few files (which we've supplied for free). The technique can be used to open other file types, but HTML is used for a reason: it is the most commonly supported by Windows (most PCs have a Web browser) and it is flexible. You could use it to open other files, such as a Powerpoint presentation, but it would require the end user to have Powerpoint or the Powerpoint viewer on their system.
The autorun zip file we've prepared contains everything you need to autorun a CD and open a HTML file. So download a copy - it's tiny and free - see above for the download link.
So why can't an autorun open a HTML directly? It is because a Windows autorun can only open an application (program) not a data file (eg HTML). You cannot tell an autorun to directly open a HTML file. Try it, and nothing will happen. To get around his problem, we are using a .bat file which Windows will treat as a program. This special file will then open the HTML file.
Assembling the CD
Download and copy the files to your root directory of the CD. These are: autorun.inf, autorun.bat and index.html. You can put all sorts of files on the rest of the CD. They won't affect the autorun. You can test the autorun by burning the three files to the root directory of a test CD-R. Open the CD drive and close it again. Viola, you have just created your own autorun HTML CD. You should change the contents of index.html to whatever you need. The index.html supplied is only a test page.
Changes you can make
The autorun can open any type of file and display any message you want. To make changes, open Windows Notepad (do not use Word, WordPad or other Word processors). Now open the autorun.bat file from within Notepad. The order is important, if you double-click the autorun.bat file, it will try to run. So open NotePad and select File-Open and choose the autorun.bat file. You'll see four lines of code.
The first line after @echo (remember the space) will appear as a comment in the autorun launch Window. This comment will be seen very briefly by your end-users. It can be changed to anything you want, but since it only appears for a second or less, don't make it too wordy. If you wanted to say 'The CD is loading now...', the first line of code will look like:
@echo The CD is loading now...
The second line of the code tells the .bat file to open to your index.html file. If want to open a file by another file (eg readme.txt), then it would read:
@start readme.txt
Make sure you leave the last two lines untouched (@cls and @exit) - they must always appear last. Save the changes and you are done. That that's all you need to create your own HTML autorun CD.
on Dec 22, 2009 | Computers & Internet
Adobe illustrator file corruption. What to do?
First check your illustrator. Could it open other files or not? Try to create new file and save it, then open again.
Try to open your corrupted file on another PC. Then if it doesn't work, it means that your file is corrupted. So you should try to restore it by Recovery Toolbox for Illustrator . You can download it here http://www.illustrator.recoverytoolbox.com/
Also you can read here about corrupted file recovery: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/513-adobe-illustrator-file-corruption
Nov 18, 2014 | Adobe Illustrator CS3 - Windows for PC...
Need the window media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
Apr 30, 2012 | Sony VAIO VGC-RB38G PC Desktop
Boot flash drive
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
http://www.intowindows.com/bootable-usb/
Or
http://www.makeuseof.com/tag/how-to-create-a-bootable-usb-drive-from-your-windows-cd/
For vista
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Hope this helps.
Let me know if you need more information
Thanks.
Apr 26, 2011 | HP Compaq nc6320 Notebook
Windows cannot open file. to open this file,windows needs to know what program created it. Windows can go online to look it up automaticaly or you can manually select from a list of programs on your...
You will need to know what program the file was created in. For example...If I were to send you a file with doc at the end of it you would need Microsoft word installed on YOUR computer to be able to open the file. Get in touch with the person that is sending you the file and ask them what program they created it in. Then you will know what program you need to install on your computer.
Hope this helps.
Jul 10, 2009 | Battery Technology for Acer Travelmate...
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
Opening downloads on emails
all you need to know is the file extension of the file you downloaded. there are some common file extensions when attaching to the email . pdf , doc, if pictures the JPG,PNG, BMP, and many more. however if u have an office application program (Microsoft office,open office) all office files will be opened but if the file extension is PDF you must download and install the PDF reader. you can download it here http://www.adobe.com/products/acrobat/readstep2.html.
Take note! Any other files which you don't whose the sender and the extension files is not on office application program not pdf or picture files maybe can harm your system so be sure to know the files.
Dec 11, 2007 | Computers & Internet
Acer Aspire T135 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
