Question about Olympus Camedia E-20N Digital Camera
Battery Problem I have trouble with apparent battery failure due to bad contacts on the slide-out tray thingie that holds the batterys. Jamming it in several times when I change batteries sometimes helps, but often the camera will stop working in the middle of a shoot and indicate the battery is discharged. A quick in-and-out a couple of times of the thingie restores full battery power, but by then I've probably missed my picture. Anyone else have this problem? Other than that (and piss-poor autofocusing) the camera is great!
    Sergeant:
  • 255 Answers
I've never had that problem, all I can suggest would be to fiddle with the contacts in the grip, or put a folded bit of paper behind the battery before you put on the little door to push it in further.
Posted on Sep 13, 2005
How do I remove and reinstall a battery in an 850? (96)
Assuming it's still the factory set up.
Remove the two 10mm bolts that hold the cables on and remove the battery cables (negative/black cable first).
at the base of the battery tray there is a hold down retainer. the retainer is like a half moon piece with a tab that hangs over the base of the battery to lock it in place.
looking at the car it will be on the front left side edge of the battery.
Lift the retainer out using a rotating motion towards the battery while pulling up on it. BE CAREFUL!!! it can take some force to remove and when it does your hand will hit the nearest bracket there.
to reinstall sit the battery into the back edge of the tray like sliding in a baking tray into a low oven. this will allow the battery housing to fit under the back lip of the battery tray.
Slide the battery all the way towards the outside of the fender (towards your right) and reattach the hold down by rotating downwards while pushing down.
reattach the battery cables and you're done. now hopefully you have the radio code... if not go by the dealer and they can get it for you (if you still have the factory radio).
As a side note, if the cables are badly corroded they can be cleaned with normal hot (almost boiling) water and a light brush. we use the hot water out of the coffee maker. when clean apply some battery protector (from any parts store) to keep the cables from oxidizing.
May 06, 2014 | 1996 Volvo 850
Tip
Fix that Jamming Slide in your Nikon CoolScan 5000ED / SF-210 Slide Feeder
I balked when someone whispered this tip to me; the thought of putting foreign objects into my Nikon CoolScan 5000ED slide scanner with its SF-210 slide feeder seemed asking for trouble.
After about a thousand slides worth of experience, and many batches that seemed to jam every other slide, I gave it a try and boy did it do the trick.
The SF-210 slide feeder works flawlessly with newer, thicker, plastic slide mounts, but if you are archiving and digitizing older, cardboard slides like I am then here's what wasn't printed in the CoolScan user's manual:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below.
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Dec 04, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Htc amaze battery life
Oops, it does not have to be, at times, I meant, supposed battery failure
If the battery contacts/pins for your phone/tab are not making contact well with the battery terminals/heads...you will experience such, constantly.
If the battery does not sit/fit well in its compartment, you will still experience same as you do at present. This is because, the battery is making partial contact with the terminals/pins.
Check these; whether your battery sits well and fits perfectly in its compartment inside your phone/tab.
Check whether the terminals are contacting well
Aside of these, you may need to either replace your cellphone/tablet's battery and watch what happens.
Feb 05, 2018 | HTC Amaze 4G Android Smartphone
4x4 low light on car will not move
The electronic module (located behind the glove compartment) controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS. Do you know what DTC'S Are ? Diagnostic trouble codes !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short Circuit to Battery GEM GO to Pinpoint Test C . P1812 4WD Mode Select Circuit Failure GEM GO to Symptom Chart. P1815 4WD Mode Select Short Circuit to Ground GEM GO to Symptom Chart. P1820 Transfer Case CW Shift Relay Coil Circuit Open or Short to Ground GEM GO to Pinpoint Test B . P1822 Transfer Case CW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Electric Clutch Relay Short to Battery GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Circuit Failure GEM GO to Pinpoint Test B . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test B . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test B . P1850 Transfer Case CONTACT PLATE "B" Circuit Failure GEM GO to Pinpoint Test B .
P1854 Transfer Case CONTACT PLATE "C" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1858 Transfer Case CONTACT PLATE "D" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1866 Transfer Case Maintenance Required (GEM Only) (4-wheel drive operation can be restored by clearing the DTC and cycling the ignition.) GEM GO to Pinpoint Test B . P1867 Transfer Case Contact Plate General Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1874 Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Symptom Chart. P1875 Automatic Hall Effect Sensor Power Circuit Short to Battery (GEM Only) GEM GO to Symptom Chart. P1891 Transfer Case Contact Plate Ground Return Open Circuit GEM GO to Pinpoint Test B Your best bet , take it to a qualified repair shop
Apr 04, 2017 | 2002 Ford Explorer
My system is having problems communicating with the battery
What message you are getting??
Possible problems:
1. The battery not seated correctly. Try reconnecting the battery.
2. The battery contacts got dirty or oxidized and the battery is not making good connection with the motherboard. Try reconnecting the battery a few times.
3. If reconnecting the battery doesn't help, most likely the battery is bad and has to be replaced.
4. If you replaced the battery but the problem still exists, this is motherboard related failure. Apparently the battery charging circuit has failed. In this case the whole motherboard has to be replaced (or repaired on component level).
Dec 18, 2012 | Dell Precision M65 Notebook
Replacing battery in my S-10 Pickup
it clips in on one side by sliding it under and just the bolt holding the wedge in place thats all nothing from under holding it in
Sep 01, 2012 | 1998 Chevrolet S-10 Pickup
Can't get battery tray out
some of the dodges have holes and slots that hold the box in place as well, try sliding it sideways either forward or back, side to side.
Jun 12, 2012 | 2004 Dodge Neon
Replace battery
The battery hold-down is a plastic block at the base of the battery. If you look on the side of the battery opposite where the cables connect, you will see a really long bolt sticking up with an 8mm hex head. (SEE PICTURE BELOW) That is your hold-down bolt. It is designed so that when you unscrew the bolt from the battery tray, you simply lift up on the bolt and it will pull the plastic block up with it.
When reinstalling the battery, make sure you slide the battery base under the lip in the battery tray opposite where the hold-dow goes, then install the hold-down.
May 29, 2012 | 2005 Mercury Montego
How do i get the battery out to replace it
Follow these steps.
1. Uncover Wiper motor and you'll see a bolt holding down collision deflector rod that mounts to grill.
2. remove that blot. usually a metric #13 socket.
3. Remove two bolts holding bar to grill. Usually metric #10 bolt
4. Slide out rod foward from fuse tray. Don't pull up or down on it. You can break Fuse tray clamps.
5. Disconect Ground
6. Disconect Hot or +.
7. Down on back of battery is a Hold Down Clamp with a metric #13 bolt. Unscrew it.
8. Lift out battery as you push Fuse tray out of your way. Good Luck.
Feb 12, 2011 | 2001 Oldsmobile Silhouette
Remote Control Altec Lansing IM600 - Battery
Turn the remote upside down. At the bottom, there is a slot that opens the battery tray and a series of grooves that are part of a clip that releases the tray. Insert the fingernail of your thumb into the grooves and the fingernail of your index finger into the slot. Ease the grooves (clip) toward the middle of the remote and slide the tray out. There is a ridge in the tray that matches the battery only when the battery is in the proper position. Slide the tray back in. If the remote doesn't work, you've probably inserted the battery in the wrong position.
Dec 31, 2008 | Altec Lansing Inmotion-IM600...
Olympus Camedia E-20N Digital Camera Logo
60 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
