Question about Sport & Outdoor - Others
2000 triumph legend loses power at higher rpms
The bike has run well up til now. lately when running at higher rpms it wants to conk out.
  • 421 Answers
Sounds like your floats in your carburators sticking also clean the needle jets and pilot jets while your in there -jeff ps please rate
Posted on Sep 02, 2008
  • jeff r
    jeff r Sep 02, 2008
    one thing i like to do is fill a container with b12 chem tool and hook this up to your fuel like and run it for about a min on b12 it will want to bog and die but just keep it going then disconnect that and run it completely out of fuel, after this you can take an air line and blow into the fuel line inlet on the carb that will clear any **** out of the jets good luck -jeff please rate
    Brigadier General:
  • Sport & Outd... Master
  • 3,614 Answers
Check the accelerator and also the fuel tank for the contamination of the gasoline.
Legend tt cuts out when put in gear
My bike cut out after a short time when the choke was released when warm. I changed the crank position sensor and did all relevant checks. took it to a Triumph dealer who took three weeks to repair the bike. They said that it turned out to be a perished carb' diaphragm which let the needle drop when as vacuum decreased when the revs dropped as the choke was returned.
Jun 10, 2014 | 2000 Triumph Legend TT
2000 Triumph Legend TT no spark
Buy a wiring diagram and figure it out.
Jul 14, 2017 | 2000 Triumph Legend TT
2001 Truimph Legend TT 900. Inline triple. At first, tachometer would briefly stop working and the bike would not idle and was very underpowered. It seemed to be running on only two cylinders. I could tell...
Hi, Stuart_goodloe nice novella, forget about the tach it's just the end result go through the checklist and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Multiple carburetors out of sync.
14. Fuel filter clogged.
15. Old or contaminated fuel.
16. Fuel tank vent system plugged or carb vent line closed off.
17. Gas cap diaphragm valve faulty.
18. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
19. Carburetor controls misadjusted.
20. Incorrect valve timing.
21. Valve springs floating, weak, or broken.
22. Damaged intake or exhaust valve.
23. Incompatible performance parts.
24. Control module may be in "LIMP" mode
25. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Triumph Bonneville Ignition Control Unit CDI Limiter Failure
TRIUMPH LEGEND TT 900 885CC SERVICE REPAIR MANUAL 1998 1999 Download... $10 cheap
Hermys Triumph Motorcycle Parts 2000 Triumph Legend TT Genuine Tools and...
Triumph Motorcycles
Triumph Legend TT 2001
Mar 08, 2017 | 2001 Triumph Legend TT
I charge my new battery and my bike runs great but the engine is not recharging it. The battery eventually gets drained and I have to start all over again.Why and how can I fix this? Its a 2000 suzuki...
If your Charging system isn't working properly it won't. Take a Multi Meter. Take the Leads to your battery. Start the Bike and run it up to 2k or higher rpm. The Voltage should increase the higher your rpms get. Up to 14vdc or about. If it doesn't go up then something in your charging system is acting up. Stator, Regulator something of that nature
Apr 03, 2011 | 2000 Suzuki SV 650
How much engine oil should i put into my 1999 triumph legend
Hi
3.5 - 3.6 litres or 4 litres with filter change
Ride Safe
Bike-Doc
Jul 07, 2010 | 2000 Triumph Legend TT
I have a Triumph TT600 2000 model. The battery keeps going flat after about a weeks riding (without lights as this makes it worse,). I have paid around $800-$900 dollars to a triumph motorcycle repairer,...
You will have to check the charging rate of your bike, normally it should give an output of around 13.8Volts to 14Volts.
If the readings are lower thn tht, thn there is a problem in the bike's charging system.
Hope this helps!
Nov 19, 2009 | 2000 Triumph TT 600
Buyinf question/maintance costs
All bikes are expensive to service. The Legend is easy to work on so buy a Haynes manual and order OEM parts from dealers or Bike Bandit. You might have an ignition coil or fork seal to go bad. I've had my Legend for 9 years and have had one of each. Every 2 years change the hydraulic fluid for the brakes and clutch. If you use fully synthetic oil in the engine it will last 6,000 miles or 1 year as will the oil filter. Replacing spark plugs is difficult but they last a long, long time. Valves are shim type and rarely need to be reshimmed. If you replace the front sprocket you will need a new gasket for the sprocket cover. Trust me on that. Good luck and ride safe.
Nov 10, 2008 | 2000 Triumph Legend TT
Sport & Outdoor - Others Logo
70 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
