Question about Microwave Ovens
GE Dual Wave II microwave oven blowing fuse
Combo unit microwave over conventional oven with all controls on microwave. I think it's a 1990 vintage. Oven still works okay. Microwave with new fuse installed lights go on and it begins to start up and then blows the fuse again.
  • shemer Mar 12, 2009
    I have GE Dual Wave II combo (Model: JKP6260K5). One week ago, I tried to head up the food and it started a few seconds and stopped. The light on the panel went out but the oven is still working. I am not sure if I can have it fixed. Or, I need to replace one.
  • William Miller
    William Miller May 11, 2010
    When does the fuse blow?
    Right after you press Start, a few seconds after you pres Start, or when it stops cooking?
    Please reply back with your model number, too, so we can help you.
I have the same issue and the same unit. I wonder if there's a recall...
Posted on Feb 21, 2010
  • Microwave Ovens Master
  • 8,973 Answers
It sounds like a shorted high voltage capacitor, a fairly cheap fix. But if it's good, I would suspect the high voltage transformer.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
The fuse blows a couple of seconds after pressing Start, doesn't make it to the cooking stage. I've only attempted changing the fuse once as I am aware there is normally something causing it to blow. The model is JKP62GOK3 BG. I have seen references to the high voltage transformer possibly being the problem. Perhaps with the age of the unit it's just time to replace? Thanks, Gary
Posted on Sep 02, 2008
    Genius:
  • 1,646 Answers
I have had this happen when either the control power supply, or the main high voltage power supply fails.
I do not suggest you try to service this yourself. There serious safety issues when servicing microwave ovens.
Jerry G.
  • angelgirl311 Jan 03, 2011
    Roberta Enterline I have a GEduo wave oven microwave convection oven that blows fuse when turned on.. the clock and all that works after you put a new fuse in but as soon as you turn on the micro it blows. the oven works ok. Is there a special light bulb for the oven
    angelgirl311@verizon.net and where is the closest repair Thanks
    I
    Roberta Enterline
GE model number jvm1790sk 01 over range microwave convection oven turns on when door is closed but i think it is the convection oven that is on cause the turn table does not turn and the light does not...
That's probably a shorted relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 16, 2011 | GE JVM1790 1000 Watts Convection /...
Hi ..Our Microwave stopped working. It is a GE Microwave- Convection Oven in wall combo with control panels for both ovens shared. Convection oven works fine. Microwave has no power...it is dead. ...
There is often a fuse and a magnetron thermal fuse or thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find links to helpful exploded view diagrams and order parts here.
Dec 02, 2010 | GE JE1460 Microwave Oven
GE Dual Wave II Microwave System and Conventional Oven mICROWAVE DOESN'T WORK AT ALL AND OVEN WORKS BUT i DON'T KNOW WHAT OVEN TEMP CONTROL TO USE. i'M TRYING TO COOK SOMETHING AT 350% FOR 45MIN CAN...
I think I understand what you mean.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
I hope this helps.
Nov 04, 2010 | GE Microwave Ovens
GE Dual Wave Microwave System JKP61G0J1 The microwave has stopped working. The panel lights come on. The timer counts down, but the microwave itself does not run.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
h
Feb 26, 2010 | General Electric Microwave Oven
We have had a lot of problems with the Advantium overheating and blowing the thermal protection fuse or switch located on the left side of the microwave. It was replaced twice under warranty, and a...
Thats a defective product, and it should have just been replaced with a new one under warranty. Any device that is blowing out a recomended fuse rating frequently is defective. The product itself is overloading the fuse, and making it blowout. Do not under any circumstance replace it with a higher fuse rating. This will make the product a fire hazard. The technician should have looked into the problem which is not the fuse.
Nov 25, 2009 | GE Advantium SCA2001BSS Microwave Oven
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
GE Dualwave II MIcrowave System - use of the convention oven time
You can download GE owner's manuals and installation instructions here.
Dec 31, 2008 | Microwave Ovens
GE Dual Wave II microwave doesn't work, all power controls are out. Is there a user-replaceable fuse?
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
Whenchecking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
If you or someone you knowdecide to look into it, we have critical safety information anddisassembly information at our site, and our link is at our listing here on FixYa.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Jul 29, 2008 | Microwave Ovens
GE Microwave XL 1800
remove top cover of oven , check fuse and control unit, high voltage section and diodes and capacitor and magnetron,
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
1,801 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
