I have a Ampeg BA115 bass amp. The unit blows the 2.5 amp fuse as soon as it is turned on. I have isolated the step down transformer from the solid state board and the fuse does't blow. So I know the power transformer is OK. What should I check next, and could you recommend a good repair service.
Duncan
  • 218 Answers
SOURCE: My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Posted on Feb 23, 2007
SOURCE: amp blows fuses
The fuses are there to protect the internals of the AMP.....
Please check that the correct fuses are installed......
if the incorrect ones are installed then a fire may develope...
There should be a manufacturers lable on the external chassis that details the fuses to use....
Fuses now days can be slow blow or fast blow....so the correct fuses must be used.....dont increase the fuse rating past the chassis panel label...but make sure they are correct...if they are correct then the amp needs a service to determine where the peak loadings to the power supply are originating from...
Some one may have installed incorrect fuses in the past...
Cheers from YUBEUT
Posted on Nov 03, 2007
jerryg50
  • 1689 Answers
SOURCE: AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Posted on Apr 25, 2008
  • 4234 Answers
SOURCE: PEAVEY TRANSTUBE AUDITION 110. PLUG
There should be an 8 pin IC close to the input jack that will be marked 4558 or 4560. This is an Op-amp Ic that is the most likely cause of the problem. Replace that IC and report the results here.
Dan
Posted on May 28, 2008
robotek
  • 1512 Answers
SOURCE: Older Peavey PA Head XR600C.
If you need a circuit for the PA board... get it from here
I would start by checking with a multimeter for shorts in driver transistors Q2 and 12
The output stage may be suspect for a driver to have failed. I would disconnect(emmitter and collector) of each output transistor for leakage and shorts in all directions (swap meter leads +ve and -ve). You can often tell at a glance that there IS a short in the output stage, by checking collector emitter with everything still connected. You cannot, however tell if there is leakage that may kill any repair work that you are doing.
Good work on the lamp. I use one in line with the mains socket on my test bench. I use a 40 watt build though.Have seen some smoke with higher wattages. I also use a variac to soft start the unit and do some DC checks mostly for symmetry in output stages with about 40-70 v into the 240 volt mains socket.
Let me know if you find any shorted transpistanators :)
regards
robotek
Posted on Jun 13, 2008
My Ampeg Ba115 will not turn on
Did you check the fuse? and power cord is good?
Dec 06, 2012 | Ampeg BA115 1x15' Bass Combo Amplifier
I have no sound. Headphone jack is working. Speaker is not. Need help troubleshooting.
With no leads connected to speaker, use an ohmmeter to check resistance of speaker. If NOT less than 10 ohms, you be replacing the speaker. Also look for loose speaker wires. More than that and is will require repair in the shop.
Aug 21, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Loud humming buzz when I turn it on
Failure, likely in the power amp causing overloading of the power supply and dragging one power voltage into the range where the ripple voltage gets to the speaker. This is very ******* the speaker as it gets high DC current and can burn the voice coil. Slight chance that a filter capacitor has failed. In either case repair is needed.
Aug 11, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Power to my Ampeg BA-115 quit suddenly whilst playing. Back of amp was hot - there was a crackle immediately before it quit. I allowed it to cool down and then turned it on, but it was dead.
Here is your schematic. Likely the fried components are visible.
http://elektrotanya.com/ampeg_ba-115.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
When repairs have been done, start this up using a 100 or 150 watt incandescent lamp in series with the power cord to act as a fuse... There likely are several components blown and you may not get them all the first time. The lamp acts as a resettable current limiting fuse so you don''t blow out what you just replaced.
Aug 05, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
The CD input on my Ampeg BA 115 works, but the 0db and -15db inputs don't. This happened immediately after using the CD input. Quick fix, or repair shop? Thanks.
Sounds like a repair shop job to me. Inputs on a amp have resistance thus there must be a issue inside hence 0DB to 15DB if you go higher well that input thus would not work anymore.
Repair shop would be your best bet for this amplifier. Quick Fix would be unplug it and plug it back in and praying it resets but that won't happen.
hope this was of some help, if not I am sure others will chime in with there 0.2 cents.
Regards
Rulds2008
Jun 15, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
My ampeg BA115HP is dead. I suppose it is the fuse. Where is the fuse located?
it's the black thing sticking out of the circuit panel on the back of the amp
May 22, 2011 | Ampeg BA115HP 1x15' Bass Combo Amplifier
Brand New Ampeg Ba 600 210. Only Used durin 2 shows. Sound is awesome. Go to use it this weekend and absolutely no sound at all coming through the speakers. Compression, eq and Everything else working when...
Another person posting on here I suggested opening his unit and he had blown speakers. I think these that are DOA after previous use may be blown during the previous shutdown of the amp driving them and those with built in amps are blown when mixer is powered down putting out a large pulse. Hopefull the amp is blown rather than the speakers... cheaper to repair. Open and check for a fuse, but dont' replace it until you find out the cause of it blowing as additional damage can occur.
May 15, 2011 | Ampeg BA600-210 Bass Combo (with )
I have a 1990's Ampeg Reverberocket guitar amp and I had it plugged in and it just made a popping sound and i noticed the fuse had blown. So I went and got the right fuse for it and then plugged it and...
Abnormal humming sound is probably unsmoothed ac mains power finding a way to the speaker. That makes the power supply the first suspect.
Carry out a thorough visual inspection of components and circuit boards and if there is nothing obvious check the power supply by isolating it from the amplifier and if it blows the fuse again you have found the culprit and then need to narrow down the search to individual components.
Nov 14, 2017 | Kitchen Ranges
All the inputs on my ampeg bass amp are not working even the RCA input is not working. the amp still turns on
If none of the inputs work, then you may have lost part of the power supply. DO NOT go into this amp under any circumstances !!!!...there is enough voltage in here to kill you crispy !! I would strongly recommend that you take it to a respected repair shop that specializes in guitar amps. Possibly visit the ampeg website for an authorized repair center. It might cost a few bucks, but the Ampeg is highly sought after by musicians everywhere !!!....thanks... Rob
Sep 01, 2010 | Ampeg Classic Series Svtvr 300watt Tube...
I need diagram eletricamplifier ampeg model ba115
if you require b115 look at abeltronics.co.uk
Jan 15, 2010 | Audio Players & Recorders
1,153 people viewed this question
 Grubhead
Grubhead
