Question about Apple iBook G3 Mac Notebook
Re: Video Card TOAST???
My Mac has a black screen. It boots up and commands light up. BUT the screen is black!
Someone wrote that I had to connect another monitor to my Mac to see if it was either the Video Card or the Onboard Display...
My new question is what kind of monitor??? And if I see the same on the monitor, and the the videocard/GPU is toast what happens?
What do I do from there?
AND if the onboard display is toast- what do I do THEN?
...And what do u think it will cost for either of these things???
I'm sorry 4 all the questions; I'm kinda a rookie. *giggles*
Amy Lou
    Novelist:
    Champion:
  • 382 Answers
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
SO, ON WITH THE QUESTION PLEASE!!
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Posted on Sep 02, 2008
  • Keith Seekwhensir
    Keith Seekwhensir Sep 04, 2008
    If it is an iBook G3, it's most likely a faulty logicboard or the GPU separating due to heat.
How to fix the LG LCD LM270WQ1 (SD) (B3)?
Rarely, a Mac may encounter some peculiar issue during system boot that can cause quite a bit of panic, like booting to a completely black screen. It would be easy to interpret that as a potential hardware problem, and in some particularly rare situations that may be the case, but it's more often a software issue that can be resolved with some simple troubleshooting steps.
Case in point; one of our readers experience with his MacBook Pro, which out of the blue rebooted to a completely dark screen. Though it's rare, we figured this would be a good opportunity to share three potential solutions to this problem, and similar issues, should you encounter a dark screen on system start.
First, Reset the System Management Controller to Fix the Black Display on Boot
The first thing you'll want to do resolve nearly every power related issue on a Mac is to reset the SMC, or System Management Controller. This will dump and reset settings for anything power management related, and is long known to resolve problems with things like fans, heat, sleeping problems, and of course, display issues.
On any modern MacBook Pro or MacBook Air with a built-in battery, which is just a bout all of them nowadays, this is how you do that:
  1. Shut down the Mac and connect it to your MagSafe adapter and a wall outlet as usual
  2. Hold down the Shift+Control+Option+Power button at the same time for a few seconds
  3. Release all keys at the same time, then boot the Mac as usual
Older Macs can find directions here for the same process on their machines, it's slightly different if you can take out the battery.
When the Mac boots, hopefully the black screen has gone away and you're back to normal, but if it doesn't... reader Nathan D. wrote in with the next tip.
Second, Try a Keypress Sequence to Ditch the Black Screen
Regular readers may recall that we covered some OS X keyboard shortcuts for the Shutdown, Sleep, and Restart controls of just about every Mac, and this little key press sequence takes advantage of those. Oddly enough, it seems to work to resolve some of the mystery Mac booting into black screen issues. Here's the precise sequence to follow:
  1. Press the Power / OFF button once - this will bring up the dialog box which you can't see
  2. Press the "S" button - this is the shortcut to sleep the Mac
  3. Hold down the Power button until a hard shut down is forced
  4. Wait about 15 seconds, then hit the Power button again to turn it back on
This key press solution was discovered by reader Nathan D., who found it tucked away on MacRumors Forums, and it has worked for several other commenters there as well. Some other users on the MR forums suggest that resetting PRAM helped them too, but most power issues are resolved by the SMC reset.
Try a PRAM Reset to Resolve the Black Boot Display
If the above two tricks failed, a PRAM reset can often do the trick, as many of the commenters on this article can attest to. As a potential solution to the black screen on boot, this is done upon restarting the Mac similar to an SMC reset:
  1. Reboot the Mac and as soon as you hear the boot chime, hold down the Command+Option+P+R keys together
  2. When you hear the boot sound again, the PRAM has been reset so let the Mac boot again as usual
At this point your Mac should boot again as usual and no longer have the black display, loading Mac OS or Mac OS X as usual.
Finally; Enter Password, Hit Return
Some users in our comments report an interesting alternative finding if they hit the black screen on boot; if they enter their regular login password and hit the Enter/Return key, the Mac boots up as usual and they're good to go. Try this out, it might work for you:
  1. When the Mac boots into the black screen, enter the password you'd use to login to the Mac as usual
  2. Hit the Return key
If this works, you'll know rather quickly because the black screen will give way to the regular Mac OS desktop.
Did one of these solutions work to get past the black screen on Mac boot for you? If you happen to run into this unusual issue with your Mac, let us know how you resolved it, and if the above tips worked for your MacBook, MacBook Pro, MacBook Air, and whichever Pro or Air model it may be. If you still need any assistance call me on +1(518)348-9393 i will be glad to assist you
Aug 14, 2017 | Apple Computers & Internet
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
Far cry 2 keeps crashing to blackscreen
When does this crashing or black screen happen? During the boot up process or while you have windows booted all the way up?
If the computer is booting up all the way except the screen is black try the steps below.
Either your monitor or video card inside the computer is bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without any problems then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If the computer is not booting up all the way then try the steps below.
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 07, 2012 | Computers & Internet
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
My Powerbook G4 has light,fan,chime on but video.
try booting with control command P and R all pressed at the same time, wait for second chime then release.
May 07, 2010 | Apple PowerBook G4 Mac Notebook
Power indicater light is orange instead of green and computer screen is black
This usually indicates no signal from the video card. If this happens at boot and no POST screen display is seen, try checking the connections between the monitor and the video card, there may be a loose cable. Inspect the ends of the cable for bent or damaged pins. Or try swapping the connection cable.
If this is happening after the post screen, then you have a video driver problem, which can be resolved by booting into safe mode, uninstalling your video card drivers and restarting into normal mode.
Hope this helps,
Gill
Jan 29, 2010 | Direct Source Distributing IBM G70 (Black)...
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
When I boot up i get the message Darwin/BSD and a login command
did you try to boot on the osX DVD, and when you have the primary interface, you go to accesories/disk utilities/ and repair disk..
Jan 22, 2009 | Apple Power Mac G5 Desktop
My iBook is Sad.
I would connect another monitor to it, if you see the same on the monitor, the videocard/GPU is toast, if not , the onboard display is.
Aug 22, 2008 | Apple iBook G3 Mac Notebook
Apple iBook G3 Mac Notebook Logo
192 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
