Question about GE RM24911 Remote Control
Programming a RM24911 to use with a Magnavox 20MS233S
Can you tell me where the code search button is on a RM24911, and how to use it to control a magnavox 20MS233S?
Thank you in advance.
Sincerely,
Roberta
  • 4 Answers
The manual gives you caveman instructions - go here for the codes...
http://www.eliztech.com/remotes/ge-4digit-tv-codes.php
magnavox - 0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Posted on Dec 10, 2011
  • 432 Answers
Posted on Sep 02, 2008
How do i get my rcr804bfdr rca universal remote to program with a magnavox tv model #20ms233s
(Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 05, 2015 | RCA Televison & Video
How do i set a code on a philips tv/dvd remote if there is no :code search: button?
Look on the remote manufacturers site for instructions on how to do this. It is usually a combination of button pushing sequences to get it into programming mode.
Jul 21, 2014 | Televison & Video
Programming the rc94927-c remote
Programming procedure is too much to type in here, and is not practical. If you wish to get more codes and other details check:
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 16, 2014 | GE RM24911 Remote Control
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
Sep 21, 2011 | RCA Computers & Internet
I need instructions for my ge universal remote
If its a plain tv you would use the codes:
MAGNAVOX ... 1174 0062 0004 0009
........................... 0183 1133 0226 0288
................. 0456 0008 0068 0075 0141
Instructions
1. Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
2. Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks, then
stays lit.
3. Enter the 4 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.With your device on,
press CHANNEL UP. If
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
Jul 15, 2009 | GE RM24911 Remote Control
I have a ge universal remote rc24993-b 2839 and i'm trying to prgram it to a magnovox tv. can you help?
Instructions
VCR, etc.). The red
stays lit.
brand.
May 14, 2009 | GE RM24911 Remote Control
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
HI MY FRIEND sreeki.
Try this site:
It's the manual for a Phillips remote control. The codes should be rather universal. Otherwise, there is a way to program it without using a code.
Hope this helps :)
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
What do I have to do?
Introduction Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are programming into the remote. While some trial and error may be required to get the right codes input to control your equipment, the pleasure at getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Difficulty: Easy Steps 1Step OneManually turn on the device you wish to program. 2Step TwoPress the Code Search button on the remote until the indicator light turns on. 3Step ThreeRelease the Code Search button. 4Step FourPress and release the button for the device you are programming. 5Step FiveEnter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. 6Step SixAim the remote at the device and press the power button. The device should turn off. 7Step SevenPress Channel Up on the remote with the device on. If the device responds, no further programming is required. 8Step EightTo look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator SAMSUNG 002 012 102 103 112 212 502 512 818 914
Apr 01, 2007 | GE RM24911 Remote Control
Televison & Video Logo
158 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
