Question about Miele Dryers
Miele dryer shorts out - Miele Dryers
  • 639 Answers
Peace Friend,
ngfam1 At your service!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Sep 02, 2008
Hi there,my (quite old) miele novotronic dryer all of a sudden trips out all the electrics when switched on, any ideas?please help!!
not safe to use
will need an electrician
not easy to get some parts for that model
possibles
plug to wall shorted internally
older the dryer more reduction of wet clothes load required
motor or bearings tired
timer or heater element faulty
safety door switch faulty
Nov 02, 2016 | Miele Dryers
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Tripping ELCB (RCB)
sounds to me like a short circuit in the heating coil circuit. One would have to ohm out the coils.
Jan 30, 2014 | Miele T8005 Tumble Dryer
Miele WT945 dryer is no longer heating but is spinning. I've followed all the steps in ww1223's useful guide (http://www.fixya.com/support/r4177912-miele_wt945_dryer_problems_stage_stage) up to stage 3,...
Check your main breaker box...It might have tripped...If so I would assume your heating element has burned out....Its behind the unit under the metal....It's shaped round..Sometimes the medal support in Laddies bra's will com out and go through the holes and short the element out... Something to look at..
Oct 12, 2017 | Miele W320 Front Load Washer
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
Miele T358C Dryer Blew up!
it could be a shorted heating element a shorted to the case, motor start capacitor, or a defective motor ,f i would inspect the first two items closely
Sep 20, 2009 | Miele Novotronic T240 Electric Dryer
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
No power
Thanks for your email. The problem was fixed, the main power board had been affected. Checked for spares and found they were available on line but the mark up prices independents were charging meant that a new machine was the only option.( It would also take 21 days to deliver) However on contacting Miele direct they were extremely happy to send us the part at half the lowest price that the independent were quoting. Their parts dept also checked that we wre ordering the right part.They were very thorough and patient and confirmed that the powerboard would take only 3 days to send. Thanks
Aug 19, 2008 | Miele WT945 Front Load Washer / Dryer
Dryers Logo
121 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
