Question about Vizio Gallevia GV42LF 42 in. LCD Television
Need remote control code for ATT U-verse
I bought this TV second-hand and would like to program it to work with my ATT U-Verse remote control, but they only have one code listed, 1259, which doesn't work. Does anyone know of an alternate code to make it work? need help to program the remote to the Vizio 42" LCD TV. When ATT Uverse installer set it up he said there was none and a subsequent tech. was able to set it up but somehow several functions quit working. Anyone??
  • treelizard Sep 07, 2008
    vizio lcd 32 in tv cannot be controlled by att remote.
    i tried the auto search as described in their tech website, which is
    code 922 for auto, but now i cannot even control the volume.
    i even printed out their instruction and followed it many times.
    i will keep searching or call att.
  • carlos monteiro Sep 22, 2013
    i need the code for one to all remote of my prosonic lcd tv B23D6D, once the originel remote doesn't work anymoe. thank you.
Well i have a vizio 32' lcd hdtv and the code 1343 worked for me!! the 922 didnt.....1343
Posted on Nov 09, 2009
1343 worked for the vo32lf
Posted on Jan 03, 2009
Vizio-compatible codes as suggested by AT&T Customer Service:
0117
0128 (suggested by documentation included with my VS420)
0178 (suggested by documentation included with my VS420)
0502
0627
1017
1018
1343 (personally worked for my VS420)
1756
1758 (suggested by documentation included with my VS420)
Posted on Nov 24, 2008
I HAD THE SAME PROBLEM WITH A VIZIO VL260M. THE CODE 1343 WORKED FOR ME ALSO.
PROGRAM MY UVERSE REMOTE TO TCL TV
0174,0179,0173,1070. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 21, 2014 | Televison & Video
Can't find a code for my ATT Uverse remote. Bought the set in China and brought it back to the US.
Hi! Welcome to FixYa!
You can program your AT&T U-Verse remote control using the Automatic Code Finder. This step cycles through all possible codes for the type of TV you are programming until the correct code has been found. Please follow the steps bellow.
  1. Make sure that the TV you want the AT&T U-verse remote control to control is ON.
  2. With your TV on, PRESS AND HOLD DOWN, the TV Mode Key on the remote control. The mode keys are located at the top of the U-verse remote control. While holding down the TV Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  • The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  • Next steps is start the automatic code finder search. Make sure you aim your remote control at your TV. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the TV turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on your TV.
  • When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the TV or DVD does not turn off, then we need the correct 4-digit code of your TV.
Please refer to the image bellow.
Thank you for using FixYa! Keep me posted. :)
Mar 12, 2011 | Televison & Video
I have ATT u-verse remote, but I don't have code to control new Hannspree 32inch lcd tv. Can you help?
I also had this problem. I talked to an AT&T technical support guy over the phone yesterday, and he told me some weird instructions. The TV was responsive to the controller but we couldn't get it to work. About an hour ago I called Hannspree technical support and they told me codes to control my AT&T receiver with their remote. I just tried the codes for my AT&T U-verse remote, just to see if they would work anyhow, AND THEY DID! Unfortunately, the codes will control the TV entirely, except turning it on.... (it does turn it off though) If these codes are of any use to you, they are: 1004 and 1018 try the first one, and if doesn't work, try the second one. If you are new to the AT&T U-verse world, these are the instructions: *Turn on your TV first 1)Hold the TV button on the AT&T remote 2)While holding, hold the OK button 3)Now release both of them 4)All the mode buttons while now flash twice (You will now have 6 seconds to do step 5, if not they will do a long flash, indicating to start over) 5)Now, quickly, type in the combination (in this case, 1004, or 1018) 6)The TV button will flash 3 times if it works, or a long flash if it doesn't 7)Now point the remote to the TV and press Power. If it turns off, IT WORKED! *Remember, these codes are the only codes I know of and they took forever to find, and they aren't supposed to work with the AT&T U-verse remote, but they did. The only defect is you can't turn ON the TV with the AT&T U-verse remote, but you can do everything else (YOU CAN TURN IT OFF)
Hope this helps!!!!
May 10, 2010 | Televison & Video
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Need Remote Code for LG LFD790 Home Theater
I NEED REMOTE CODE FOR LG LFD 790 FROM REMOTE GE
Dec 30, 2008 | LG LFD790 System
I have ATT U-Verse and the LG LFD790 Home Theater System. I can program the U-Verse remote to turn the LG on/off, but can not control volume from U-Verse remote. Do you have any codes I can try?
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Use the code search method. MANY TV's are branded from a few suppliers. Emerson has about 50 codes!
Mar 02, 2008 | Durabrand DWT1304 13" TV
Vizio Gallevia GV42LF 42 in. LCD Television Logo
11,111 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
