Question about Rowenta DZ1700 Iron
Rowenta Iron problems
My Rowenta, model #DX1700, lights up when plugged in for only about 30 seconds and then the light begins flickering and does not heat up any longer.
  • 5 more comments
  • diann333 Sep 02, 2008
    My rowenta DX1700 heats up when plugged in for about 30 seconds and then the light begins to blink and it does not heat up any longer. What is the problem?
  • Anonymous Oct 21, 2008
    same
  • Tamika Lee Nov 11, 2008
    I have the same problem. What's the solution? I'm running late for work because I can't get the iron to work!!
  • romalo Dec 19, 2008
    Hmmm. three of us with the exact same problem...does anyone see a recall in the making?
  • Anonymous Feb 21, 2009
    Same Thing! Darn auto-off light continues to flash
  • auntmoe043 Mar 29, 2009
    Green light goes on, in the middle of ironing, red light or yellow goes on then the heat goes off.
  • Anonymous Apr 05, 2009
    same here for a model 353, but it's way out of warranty. If I shake it just right, it will work for a while.
    New Friend:
  • 18 Answers
Inside the iron is a thermal switch that has failed to make contact. Dissassemble the iron and you will see a small white ceramic pin sticking up out of the heating chamber and on tip there is a small contact. Above it is another contact that makes the heating element work. Easiest way to fix is to put a small bead of glue on the housing to force the contacts together.
Posted on Mar 06, 2009
  • 2 more comments
  • wizzard8955
    wizzard8955 Mar 06, 2009
    Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
  • wizzard8955
  • wizzard8955
    This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
  • CoogPower
    CoogPower Feb 16, 2017
    I realize this post is now almost 8 years old but I thought I'd still give a try. Do you have an image or some other guidance on locating the ceramic pin on a Rowenta DW 9280? I've taken it apart and found a tiny metal ball rolling around inside. I'm assuming that's the small contact from the tip. My iron would do everything but heat up, i.e. light up, etc.
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
We have a Rowenta iron effective model DX1700, less than a year old. It will not heat. Is there an iron made that will give satisfactory service for more than a year? Are they repairable?
If the cord and plug are ok (the wires in the cord often break just at the cord protector at the iron) the most likely other problems will be the thermal fuse(s) or the element. Thermal fuses can be replaced but if the element is gone that is unfortunately that. Take the back cover off and check for continuity from the plug to the inside connections using a test light or multimeter (the iron is of course unplugged).
Jan 19, 2011 | Rowenta Irons
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Rowenta d1700 red flashes and iron shuts off
I am on my 3rd or 4th Rowenta. I recently bought the Rowenta Effective, Model DX 1700. Once again, I am having the same problem as before, it shuts off after about 30 seconds. From what I am reading, many people are having the same problem. I'm going to have to guess, this is a product defect. Do I contact the company for a refund????
Dec 03, 2009 | Rowenta Effective DX1700 Iron with Auto...
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Not heating
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Mar 24, 2008 | Rowenta Effective DX1700 Iron with Auto...
Hi have a nice day! Ensure that the unit is tightly plugged into a working outlet.
Some units are equipped with our patented Motion Smart Auto Off technology. Moving the iron will cause it to begin to reheat.
Mar 16, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta DZ1700 Iron Logo
846 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
