Question about Bernina 1008
Threading a bernina serger
I have a bernina serger 800dl and I a have forgotten how to thread it. I've had it for about 7 yrs and the last time I used was about 6 yrs ago. I can't find the manual. I need help!!
  • 1 more comment
  • christyboys May 11, 2010
    I have lost my Bernina 2000DCE Overlock Serger manual. How do I thread the machine?
  • Anonymous Mar 12, 2014
    Need a manual for bernina 150
  • Anonymous Mar 14, 2014
    bernina 800dl juki
  • 202 Answers
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Posted on Oct 18, 2008
  • Bernina Master
  • 11,515 Answers
You can download a Bernina 800DL manual from the web site. Click on Support and scroll down to Search Support Info for Bernina Machines. Then scroll down to Bernina Overlockers to find your model.
Posted on Mar 25, 2015
I would like a diagram of threading help that is big enough to see, for Bernina Serger 2000 D , NOT 2000 DE. Or maybe I have just BERNINA 2000. Please. I have the manual. JOELLIE@SHAW.CA
If you view the book online, you can usually enlarge the view.
Easy Instructions for Threading Bernina Serger eHow
Start out with NO thread in the machine.
ALWAYS RAISE the presser foot during the threading process.
When threading through the tension guide below the thread tree and through the tension disk, give each thread an extra little tug to make sure it is completely seated (it may even make a little popping sound when it seats).
ALWAYS THREAD each IN THE CORRECT ORDER (upper looper first, lower looper second, then the needles). When threading the lower looper, ALWAYS FINISH with the lower looper thread draped OVER THE TOP of the upper looper.
If a serger looper thread breaks, it is most often easier (and much less frustrating) to unthread the entire machine and start from the beginning. Trying to fish a thread through only works about 1% of the time, Just bite the bullet and do it!
When unthreading the machine, NEVER pull the thread UP through the tension disks! Instead, cut the thread below the thread tree, RAISE the presser foot and pull the cut threads down and out.
The Bernina Serger Workbook may be helpful, found here:
Jun 15, 2017 | Bernina Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
How do I thread the Bernina Overlocker
Depends on your serger model. Best idea is consult the owner's manual. Some manuals are available for download on Bernina's web site (look under Support). Be sure to thread in the order specified in the manual. Usually the upper looper is first, then the lower looper second, then the needles. (Hint: The lower looper thread ALWAYS lays over the top of the upper looper thread in the final looper threading step.)
You can also download a serger workbook too.
BERNINA of America Premium Swiss quality sewing machines BERNINA
Aug 25, 2015 | Bernina Sewing Machines
My thread keeps breaking on my Bernina 800dl serger
Is the thread aerial raised up ensuring a good thread flow?
Which thread is breaking, needle or looper? If you can establish which thread is breaking, then check that tension dial, turn it to zero and clean between the tension discs by sawing a selvage edge of cotton fabric offcut between the two discs to remove any fibres, dirt or debris.
Now turn all dials to zero, unthread the needles, and pull on each thread, feeling if there is any resistance. If there is, check back through the thread path and find where the thread is catching.
Serger threads flow very fast and the thread path can't be compromised or the thread snagged.
Check the thread path from the cone to the sewing foot, and ensure that the thread is not catching on something, or getting caught around the cone, cone holder or aerial somewhere in the path. Look at the thread cone, has the thread feeding off got looped around itself somewhere? Open up front of the serger and look at the thread going through the loopers, is something misthreaded here, sometimes there is a part that slides on a looper to make threading easier, just check it is all threaded up correctly. There should be a threading diagram inside the serger cover usually showing the paths.
Rethread the needle(s) and pull all the threads under the pressure foot, lower the foot, turn tensions back to 5, then chain off and test sew.
If no joy after trying all this, I'd take it for a ride in the car to the shop.
Apr 14, 2011 | Bernina 1008
Bernina 800d sewing machine
You might take a look on ebay item with bernina 700d/800dl instruction manual
Apr 28, 2010 | Bernina 1008
My Bernina Serger 800DL is not sewing right. I have threaded it twice and it still doesn't work. Can you help me with this problem??
Sometimes you have to remove all the thread and start over.
Make sure:
The needles are inserted properly.
The thread antenna is fully extended.
The loopers are at their highest position.
The presser foot is up.
The tensions are open/zero.
Begin threading from the right to the left.
Good luck - I gave in (and saved the life of my old serger) and bought an air-jet threading serger.
Apr 27, 2010 | Sewing Machines
Need manual for bernina serger 1300dc
I have a Bernina Overlocker/serger 1300DC having trouble threading the machine
Sep 23, 2009 | Sewing Machines
Bernina 2500DCET serger keeps breaking the centre needle thread for no apparent reason .Already had machine serviced,new needle plate didn't solve anything either. Any ideas
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Mar 01, 2009 | Bernina 2500DCET
Sewing Machines Logo
2,204 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
