Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Blows fuse.s when i hook up the coax
This radio workes in the house. But when I try to hook it up in the truck. it blows the fuse every time.
  • 90 Answers
The polarity is reversed. The red power lead must go to +, the black to -. Most trucks are - ground but yours may be the opposite.
Posted on Sep 05, 2008
65" projection toshiba power fuse blows
You have a dangerous situation here---All modern units (Lamps, TV's, everything) Have a polarized power cord---one side of plug the pin is smaller than other side.
The large side goes to the neutral side of the electrical outlet.
One of two things has happened---either a issue with the electrical outlet which is rather rare except in older houses that have the old style electrical outlets (both pins the same size) Or someone has managed to get a cord in backwards--filed down the large lug on the power cord and put it in backwards.
What happens and can be tested is with it backwards you have "potential" 120 volts being fed back into the cable wire itself--
DO NOT KEEP CHANGING THE FUSE--a simple test with a voltmeter set to AC (wall) voltage from a earth ground (water pipe of metal will show 120 volts on the coax.
The touchy part is any set in the house misconnected can feed this back via the coax!
The cable company may be able to help or NOT> an electrician will be able.
The way I would locate this is with the volt meter hooked to the coax I would disconnect the cable feed from each set or unit in the house one at a time until no voltage reading---then you would know which is causing this issue.
Be advised it can spark which can destroy parts in any of the sets or equipment.
Kind of like if you got shocked when you touched the metal on your car.....something bad is happening.
Please if need ANY help comment here and I will assist.
Dec 03, 2012 | Toshiba 65HM167 65" Projection Television
When i I plug in my coax I get 9 pound plus of static could this be down to bad coax and what would b the best replacement.
first of all,your radio should not even be on when you plug in your coax.second , what time of day is it? Third ,it could be bad coax. the coax you need should be 95% shielded or better and the dielectric should be and the plastic outer cover marked with type " IIA" this coax has a life time of 20 years. It is the best you can get.Is your radio a mobil or a base? A base could be picking up flouresent light energy and your car radio could also .If your car radio is hooked up to a cigarette lighter plug you can pick up extra noise that way.Try going directly to the fuse panel. It could be just a minor adjustment to the RF gain section or the Squelch section.You will need a tech.
Sep 24, 2012 | Radio Communications
Hooked up cb, blows fuse when the mic is keyed
when mic is pressed transmitter is engaged. First is the Fuse the proper fuse? Could be an antenna-coax problem. Get a dummy load and hook up to your CB and try it again. If it doesn't blow the fuse, the problem is indeed in your coax antenna system. another way to test your antenna coax is to disconnect it from the radio, take a multimeter, set it to ohms 200 ohm scale, put one lead on the center pin of the coax and the other on the outside of the connector on the coax.if it shows anything at all, you have a short and that will not work. It needs to not read anything. To be sure the antenna system is ok other than swr you can also check the coax an antenna for continuity. one lead of meter on the coax center pin then other on the antenna. should get a reading, a low value. again on the outside of the coax at the connector and at the antenna side on the outside of the coax connector. should be a low reading. but you cannot have a reading from the center of the coax to the outside of the coax. disconnect the coax at the antenna and measure from center to outside at the coax if the previous reading showed a value.If you see a value on the meter, any value, your coax has a short. not good. most likely at the coax connector. redo the connector. It is possible that the coax got compromised somehow and got smashed to the point the outside coax meets the inside and touches.
Now the other possibily your fuse blows, kis because the final output transistor is bad. So if you hook up a dummy load to your radio and the fuse still blows, then the final transistor is bad. This is probably due to a bad coax-antenna system. So before you replace any parts check the coax-antenna system first or you will have the same problem and burn out another transistor in the final. If none of this helps then just get another radio or have a god buddy look at it that knows about radios. Trade him another radio or something to fix it.
Feb 08, 2011 | Radio Communications
I have a uniden pc68ltw cb radio and it keeps blowing the 2amp in line fuse i tried a 5amp but still blows the fuse.i hooked it into another truck to test it but still blew the fuse. something wrong with...
have you been using the uniden pc68ltw cb radio without the fuse blowing before?
If the uniden pc68ltw cb radio has not been blowing fuse before, then might be a problem from the radio. This problem should be a power related problem.
The fuse blowing means there is excess of current. So while your trying to refuse, thicken the wire.
Best regards.
Feb 23, 2010 | Uniden Radio Communications
How do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Nov 04, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Got 60 inch when hook cable tv coax to it blows fuse on board
The cable or your house wiring is improperly grounded - measure(AC voltage if you have a meter) from the casing of the cable to the outside casing of the TV connector. Call the cable provider to have them check their line.
Oct 23, 2009 | Televison & Video
Radio Fuse blows
any time a battery is hooked up backwards anything that contains diodes will have to be replaced.unplug the radio and see if you can put the fuse in without it blowing.when you get the vehicle going have the alternator tested,it also has diode in it.good luck.
Sep 30, 2009 | 2000 Nissan Xterra
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Blowing fuse
Your polarity protection diode has been blown. If you tried hooking up your CB and accidentally pushed the plug in backwards. Inside the radio, there are 2 big black diodes near the transformers, D8 and D23. Replace these with the same or bigger. You can the burnt one out and the radio will work, but if you hook it up wrong again, it will fry the radio.
May 02, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Tail light fuse keeps blowing
where do you have the power wire for stereo hooked or hooked into?
Jan 18, 2009 | 2001 Lexus IS 300
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
71 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
