Question about Microsoft Xbox 360 Console
360 wont read discs
My 360 will not read any discs at all.I put in a game or dvd and it says reading and then just does nothing.Can you help me
    Scholar:
  • 26 Answers
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Posted on Mar 13, 2009
    Sergeant:
    Champion:
  • 285 Answers
The lens either need cleaning with a disk cleaner or the lens will need to be replaced.
jonno
Posted on Sep 05, 2008
4 Suggested Answers
xboxexperts
  • 19 Answers
SOURCE: 360 reads game discs but it won't play game and it says play DVD
The problem is that the laser is either dying out, is dirty, or is not getting enough power.
so try to fix it using these steps...
- first open the 360 and pull out the dvd drive and open it up too.
- clean everything out good with compressed air, and q-tips dipped in alcohol.
- now you need to adjust the power going to the laser.Sometimes you may have to try multiple settings before getting it justright. Just keep adjusting the resistance lower and lower until itworks.
- if you tried multiple settings and still get the errors, then either get a replacement drive, or a new laser for it. Click Here for how to properly install the new laser.
- if you get a replacement drive, please not that there is a key in the pcb of the drive that must match the key from the motherboard, so you must either spoof firmware with the key, or swap out the old pcb board and put it in to the new drive.
If you need more dvd drive repair help click here
Posted on Mar 06, 2009
SOURCE: my xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
Posted on May 29, 2009
  • 11 Answers
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
Wht does it mean when you put a xbox 360 gme in the console and it says play dvd and sometimesa wont read the game discs
When it says play dvd, it just randomly doesn't recognize that it's a game. Press A and you'll enter the game.
When it doesn't recognize the disc all together, I'd suggest cleaning the disc with an anti-static cloth then putting the disc back in.
Mar 05, 2011 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Fable 2 for Xbox 360: game wont read says put disc in xbox 360 but i am ...
One. Make sure the bar code on the band on the inner ring is perfectley clean and dusted. Two blow into the disc drive to make sure there is no dust on the laser. Three, get a professional to look at it such as a person at Game or at Gamestation. Four, try replacing the copy (NOT RECOMMENDED YOU COULD WASTE MONEY)
May 18, 2010 | Microsoft Fable 2 for Xbox 360
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Disc Reader not reading disc
You can try to Clean with dvd cleaning kits...if doesn´t work..the only way fix is to disassemble the 360 and force the dvd laser adjusting the micro pot...located under the laser unit..But you will loose warranty and I think that the best way is to send your game console to microsoft...what hurts is that $140,00 you can buy 02 or even 03 xbox drives on ebay. Choose the best way! Good Luck!
Sep 10, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
May 29, 2009 | Microsoft Xbox 360 Console
My 360 does not want to read the games
theres nothing you can personally do i would reccomend geek squad at any near best buy... there cheaper and get the job done
Mar 28, 2009 | Microsoft Xbox 360 Console
Reads games as DVD
Does it happen with all your games or just one and which game
Mar 10, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
