Question about Memorex Televison & Video
Sound Distortion on Mlt1912
We use our Memorex MLT 1912 in our travel trailer. When we hook into an RV campground cable the sound is distorted with static and garbbled sound.
We have changed the outside cable, but it doesn't help.
  • Anonymous Oct 26, 2008
    Have you found a solution to this yet?
    I purchased two of these because of the 12V capability and find that they are both equally distorted on my home catv connection. Have you found a setting that worked? Is the audio OK using an antenna?
    I left a message with memorex customer support and will try a dvd player to see what that sounds like.
  • 3 Answers
The hard way, if you have the skill, is to replace the speakers.  The bad news is that this probable won't fix it as it is likely that it is internal noise causing the distortion.
there is an easy solution that will probable work.  Using the audio output connection you could hook it up to a stereo system or boom box and use those for sound.   the only thing technical is making sute your cord has the right connectors/adapters on each end.  take a picutre or a good look at both devices audio connectors (output on the TV, input on the Stereo/boombox) and the salesman at your local electronics store should be able to help you find just what you need.
at a guess you will likely need an RCA female to RCA female cord or an RCA to stereo mini male.
hope this helps.
Long_Knight
Posted on Apr 01, 2009
How do you update a memorex lcd mlt 3222
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 08, 2014 | Memorex MLT3221 32 in. LCD TV
I dont get a clear sound even though the picture is clear
First of all take the Audio output from the LINE OUTPUT and connect to an external amplifier. If the sound is still not clear then it is possible that the fault is in the SIF section provided this is the sound distortion from a Tv program/cable program. If this is a DVD or DTH input then the distortion can be from these input units. So please confirm on them.
If the sound does not have distortion then the fault is in the OUTPUT of the audio amplifier in the TV, Possible the output IC or the coupling capacitor are defective.
Jan 21, 2011 | Televison & Video
I need remote control for an memorex model MLT1912
oscaramilcar,
Try one of the links below:
http://www.newremotecontrol.com/Mfrs/Memorex/Memorex/HS-Y3719-BLK-320.htm
http://www.remotes.com/store/memorex/mlt1912.html
-Chris
Aug 24, 2010 | Memorex MLT1912 19 in. LCD TV
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have no picture but do have sound whats wrong?
check your VGA cable is it working...because the sound is operated from the desktop PC itself and not from the screen, if sound is OK,meaning that system unit is OK but screen problem, check VGA cable. (cable from screen to PC)
Oct 05, 2009 | Memorex MLT1912 19 in. LCD TV
How do i make my two l5 10 subs sounds with clear
Try these:
Make sure the gain isn't set too high. That's a very common cause of distortion. You'll never want it set above 3/4 of the way to high. It will be a small dial on your amp marked "gain".
See if your receiver has a built in crossover on the channel your amp is hooked up to and set it so the cut off is at 400hz if possible. Meaning that the receiver will only send frequencies of 450hz or lower to your amp
Look on the amp for a built in crossover to the channel your amp is hooked to and set it to 450hz.
Make sure the cable that connects your amp to your stereo isn't running near any power cables of any kind because electricity running through a power cable can be picked up and then the sound it makes will be amplified, sent to your subs and cause distortion.
Make sure your amplifier isn't grounded to
your battery as this can cause what's called ground loop noise...also distortion.
Ground your amp as far away from the amp itself and your subs as the manufacturer safely recommends.
If none of those help then i'll try again :)
Apr 06, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Poor speaker quality - distorted Memorex mlt1912
yes speakers can be replaced. but more likely tobe circuit prob if your handy you could switch speaker wires. to ck.
Dec 01, 2008 | Memorex MT2245 TV
19 inch portable TV Memorex
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Dec 31, 2006 | Memorex MLT2022 20 in. EDTV-Ready LCD...
Televison & Video Logo
69 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
