Question about Epson PhotoPC 850Z Digital Camera
What is the battery life using the LCD with this camera?
    Master:
  • 542 Answers
Batterie life seems to be a couplre of hours of continuous use. I don't know how this compares. I can't seem to get regular AA batteries to make the camera work in LCD mode.
Posted on Sep 13, 2005
SOURCE:
New batteries are not lasting longer than a day
Battery life can fluctuate greatly from day to day. It all depends on the type of photography you are doing. For example, on one day, you spent the day taking pictures outside in the sunlight, with no flash, and didn't use your camera's screen to review any of the pictures. The next day, you spent the day inside, taking lots of pictures using the flash, zooming in and out on people's faces and reviewing the pictures using the camera's screen.
Features like the flash, zoom, LCD screen and image stabilization (IS) use a great deal more battery life than if you were to not use any of those features. This could explain why it suddenly seems like the batteries aren't lasting more than a day.
However, if your photography habits have not changed enough to potentially affect battery life, there could be an issue with either the image stabilization hardware or the standby mode of the camera. If the image stabilization (a fully mechanical feature) is malfunctioning, it could be activating when it shouldn't be, such as when the camera is on but you aren't about to take a picture.
I would try testing the camera by taking pictures using different camera settings.
  1. Turn off the flash and image stabilization, use the viewfinder instead of the LCD live view mode, do not zoom in or out. Take as many pictures as you can before the batteries die.
  2. Keep the flash and image stabilization on, use the LCD live view mode, use the zoom frequently. Take as many pictures as possible before the batteries die.
With test #1, you should see much better battery life than with test #2. If you still experience decreased battery life either way, there may be a hardware issue with the camera. Should this be the case, contact Canon Support to find out whether or not your manufacturer's warranty covers this problem.
Mar 01, 2011 | Canon PowerShot SX20 IS Digital Camera
Batter Life
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
Kindly regards,
micro
Feb 28, 2008 | Samsung Digimax S630 Digital Camera
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
How can I increase battery life?
Transferring images from the camera to the computer requires a lot of battery power. It is recommended to use the AC adapter when transferring pictures to conserve battery life. If not using the AC adapter, make sure your batteries are fully charged and use the highest possible serial speed when connecting the camera to the computer. After transferring your images remember to shut off the camera, otherwise the camera will remain "awake" and will continue to wear down the batteries. The LCD display also uses much battery power and should be used sparingly when trying to conserve power usage. Battery life can be improved by using AA sized lithium batteries, rechargeable AA Ni-Cad batteries, or rechargeable AA Ni-MH batteries instead of AA sized alkaline batteries.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Extend the life of my batteries
Using the flash and LCD monitor affects the rate at which the batteries will drain. The rate at which pictures are taken will also affect battery life. When taking pictures sequentially the battery does not have as much time to recover between each shot. To help to extend the life of your battery, the flash, LCD monitor, and sequential shooting should only be used only as necessary.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
What causes bad battery life?
Bad battery life has a number of major causes: The primary causes are: Selection of the wrong battery chemistry or type for the camera used Extremely power-intensive use of the camera A damaged battery (probably the least common cause of bad battery life) The way in which the camera is used is at least as important as the battery chemistry selection in influencing battery life. The highest power-usage modes in any digital camera will be video and live preview. Thus, heavy users of these modes will see the shortest battery life. Other significant power consumers are the strobe, zoom motor, fill flash, and the image LCD display. For longer battery life, use these modes only as necessary.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Epson PhotoPC 850Z Digital Camera Logo
29 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
