Question about Onkyo TX-DS575 Receiver
Hookup Audio to new Samsung 52"1080 TV LN52A650
Exactly how do hook my audio (5 spearkers) from the TX-DS575 to the Samsung LN52A650. What cables do I need?
Mark
  • mblindma Sep 02, 2008
    I have access to both user manuals (the TX-DS575, and the LN52A659). It is not clear to me exactly what is required to hook these 2 units together. That is why I just paid $9 as opposed to posting (free) to your forum. To get a rely to read the manul is certainly not woryth $9. Please look at both manuals & give me solid advice on how to conned them together.
    OK, if I understand it - use an optical cable and run it from the TV's Digital Audio Out (Optical) jack to Digital Optical1 input jack on the TS-DS575. Correct?
    If I also want to run a DVD player thru the TS-DS575, I would have another optical cable from the DVD player to Digital Optical2.
    Is this correct?
  • 10,594 Answers
You can connect TV digital audio out terminal to digital input terminal of 5 speaker receiver for beautiful sound.
Regards,
Posted on Sep 02, 2008
  • Shahid Electronics
    Shahid Electronics Sep 03, 2008
    If you want to connect DVD Player with Receiver, Audio connections depends on options available on both units. If DVD Player has digital optical out, then its fine and you can use Left-Right audio out RCA pins as well to connect it to receiver.
    Genius:
  • 1,847 Answers
The best way is to check the user manual. If you dont have i can provide one.
How do connect surround sound receiver to my tv
use the optical port (toslink cable needed)little square with flap will be lit red or use rca cables red and white audio out fron tv to any port on reciver(aux,cd,dvd,ect) the reciver will have to be turned to this for the surrond to be heard
Sep 06, 2014 | Onkyo TX-DS575 Receiver
How to hook up tv to onkyo txds575 receiver...
Red and white plug into the component audio inputs (red is right and white is left) and yellow plugs into component video input
Jan 27, 2013 | Onkyo TX-DS575 Receiver
Hookup the comcast hd box to my new lcd tv?
You can use either component (Red/Green/Blue video and red/white audio) or HDMI cables to connect the Comcast HD box to your TV. Most times you can get these cables for free at the Comcast front counter.
Sep 26, 2009 | Onkyo TX-SR606 Receiver
I have an onyko receiver tx ds 575 the sound from my tv to receiver to speaker is very low can't figure out why need help thanks
have you ckeck the tv config??
sometimes u need to select in the tv menu, in audio option to have continue output, otherwise when you turn the volume up in the tv the amplifiers sounds more, have you try this??
or check the cable maybe is damaged.
Good Luck
Jan 10, 2009 | Onkyo TX-DS575 Receiver
Hook cable box to this receiver
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
Let me know if I clearify any of this.
Jan 02, 2009 | Onkyo TX-DS575 Receiver
Suggestions to hook up HDMI cables
I'd suggest running all HDMI.  I believe your receiver has 2 HDMI in's and one out.  Run the out to your TV and run the components to the inputs on the receiver.  This way the receiver will control the video.  Works good for me!  Hope this helps!
Dec 27, 2008 | Yamaha RX-V663 Receiver
PCM vs Dolby Digital
OK, I just figured this out. Go to the audio options in your DVD player and switch from pcm to bitstream. Now my movies sound right again.
Nov 16, 2008 | Onkyo TX-DS575 Receiver
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
Oct 05, 2008 | Onkyo TX-DS575 Receiver
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
196 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
