Question about Epson Stylus 2200 InkJet Photo Printer
Still having Ink pad woes...
Hey Worldvet, I will gladly give you a thumbs up and a fixed sign for your efforts and valuable time especially free of charge, but my printer is still down. The link you sent me is an  .exe file which won't open on my MAC. Do you have a link for MAC users? Also how do I empty the ink reservoir in the printer that it's claiming is full? Won't it eventually be completely filled?
artdude08
    Guru:
  • 859 Answers
Didn't know you were on a Mac, which does make a difference.
The link I sent you is a direct download link for a utility to access and flush the counter in your printer.
It is highly unlikely that your reservoir is full. Nearly all these warnings are simply a result of the print counter reaching a pre determined number which then creates the warning alert and trajically halts all printing.
I can check to see if there is a Mac version of this utility and/or just send you the url to the page where the download link is located.
Your browser not allowing an exe to open or in this case directly begin downloading is a security feature with a default property denying this outbound link to an exe from being accessed. In general, this is a good thing as it traverses across domains.
To access the reservoir would require you to do some disassembly and some people consider themselves to be skill enough to do this, I've found on this web site's customers. You however may not and that's okay. You're only option would be to opt out of the do it yourself nature of our solutions here at FixYa and visit a qualified tech.
There was a time when I used to get a lot of printers to clean and repair. But, printers are nearly considered to be disposable, much like the VCR and DVD players. That is to say, the cost to repair is greater than the cost to replace.
Bottom line in your case: your printer's counter has exceeded it value set at the factory. Your reservoir is 'not' full, based on our collective experience, you would have had to be refilling your own printer cartridges (which notoriously leak) to actually have a full ink tank. The ink tank full warning is actually an after market method of generating more income in the printer seller channel. How to reset this number is a closely guarded 'secret' so to speak. I do not have this memorized.
Do you have Windows Boot Camp on your Mac? So you could run a Windows based program?
Let me see what I can do. I actually do not think this is available in Mac or that the sequence will work off a Mac platform.
Regards,
Worldvet
Posted on Sep 02, 2008
  • Glenn Rogers
    Glenn Rogers Sep 02, 2008
    Here it the web site to download from. This will stop the cross domain traversal of the download and that perhaps will allow your browser to download the software.
    http://inkjetprinterhelp.us/epsonSSC.htm...
    I did not see a version for the Mac. So Boot Camp is your only way of giving this a go. Try to run Boot Camp and then install this software and hope it works on your Mac. It is a great utility for you printer and hopefully you can have this great tool on your side.
    You will also find a link to disassembly instructions.
    Otherwise, try this key sequence on your printer.
    Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and again. Most people state they get it eventually. That is to say, if Boot Camp won't run or work. I sort of doubt it will, but try anyway. Its designed to create a Control Panel Icon in Windows.
    [thanks to fixyourownprinter.com for this solution]
    Printer Onboard Control Panel Key Sequence
    "Press and hold the paper feed, paper switch and the power switch.
    Once
    the power light and paper light flashes twice and the other lights are
    flashing release the paper feed and paper switch and then press the
    paper feed switch.
    The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
    Don't give up if it does not reset the first time. The timing is tricky for most people.
    Let me know how it goes so I can share the results with some other experts here I'm close to.
    BTW, you've created three threads on this topic so when we are in fact done, we'll need to close them all out. OK?
    Regards,
    Worldvet
5C00 Error Code as well as yellow and green alternating lights
To fix this error is much easier than it looks. Unplug the printer power. Move the ink cartridge cradle to the left. Over to the right you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now.
Jan 14, 2017 | Office Equipment & Supplies
Printer error 5C00 printer carriage not moving across pixma ip3300
Fixing this error is much easier as it looks.
1. Unplug the printer completely.
2. Move the ink cartridge cradle gently to the left.
3. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink.
4. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently.
5. Squeeze the pad several times between your thumb and forefinger while inside the microfiber cloth to remove ink build up.
6. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too.
7. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now.
But it's worth checking for any paper caught near the ink pad as my error occurred after a paper jam. Good luck smile.png
Jul 23, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
I have error message 5c00
Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad as my error occured after a paper jam.
Jun 09, 2010 | Canon PIXMA iP90 Mobile Printer
Error Code 5C00
Fixing this error is much easier as it looks. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad as my error occured after a paper jam. Good luck :)
Jun 07, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I get Service error 5C00 for my Cannon i80
Canon USA has a down loadable file for the manual.
Here is the link.
Here is what is being said of this error on the forums:
Apr 28, 2010 | Canon i80 InkJet Printer
Waste ink counter reset for canon pixma mp190 photo all in one
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Nov 29, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Cannot get printer to print
1. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad as my error occured after a paper jam. Good luck :)
Make sure to clean all the parts thoroughly.
If this does not resolve your issue, let me know.
Jan 09, 2009 | Cannon Office Equipment & Supplies
Canon Pixma MP 110 Model Display sign comes on "Waste Ink Absorber Full" and printer won't work.
Hi There this is old posting but you may call back
How To Reset Waste Ink Canon Pixma MP130
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 06, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Response to solution one Ink pad woes
There is a method to clear the counter and I think it is posted here somewhere. It is a sequence of keys on the printer control panel.
I'll see if I can find it for you.
WV
Aug 30, 2008 | Epson Stylus 2200 InkJet Photo Printer
Ink pad woes
Sorry to be a few days in getting back to you. We had a death in the family and settling all the affairs has occupied most of my time for most of this past month or so. All is settled now, except for the memories.
As to your question, there is some variance from one maker to another and from one model to another.
I believe in your case, excess ink is carried out a flow tube to a reservoir and after printing a fixed number of times the Epson software gives you a warning message that the ink tank is full and to empty it.
Is this the case in your model? You are not seeing absorber pads?
When the print head cartridge is at rest a platform rises to seal off the print heads and prevent them from drying out. It is this platform that has the excess ink overflow tube that runs to a reservoir.
So, let me know if I'm spot on or way off base and if the later, give me a hint as to what you are seeing and what the problem happens to be. I'll be glad to help you get through this and if need be I can bring another expert into this discussion.
Regards,
Worldvet
Aug 27, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
270 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
