Question about Refrigerators
Refrigerator energy consumption
We have a Danby fridge Model D730W/TG,Type HDS 201, Volts 120, Hz 60, Amps 1.4 , Design 235psi high/140psi low. We don't know how old it is, but we would like to know what the energy comsumption per year would be. We have searched online and were not able to find it. Thank you
    President:
  • 1,462 Answers
Power usage is 270 watts but how much is used in year depends on its cycle time which in turn is dependant on weather etc. there isn't a simple answer
Posted on Sep 02, 2008
I have steamvac 120 V 60 HZ 7.9 A im going to use in my country Argentina 220 V 50 HZ input i need a tranfo 220V 110 V and who many watts?????
220 volts at 7.39 amps = 1738 watts
120 volts at 7.9amps = 948 watts so any unit capable of 1000 watts at the 110 volts will do the trick
Jul 11, 2017 | Audio Players & Recorders
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
    less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
    Dec 04, 2017 | Pool & Spa
    Trying to find the right fuse for a eden World Tour 800 bass amp
    Well, hope this helps you.
    Fuse Requirements:
    USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
    Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
    Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
    Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
    What should i set the micro switch on the back at?
    Power:
    2 ohm stereo (per channel): 975W
    4 ohm stereo (per channel): 660W
    8 ohm stereo (per channel): 400W
    4 ohm bridge-mono: 1950W
    8 ohm bridge-mono: 1320W
    Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
    Voltage Gain to 1-kHz, 8-ohm rated output,
    CE 1000:
    30.5-dB gain at 1.4-volt sensitivity;
    26-dB gain at 2.34-volt sensitivity.
    CE 2000:
    32.1-dB gain at 1.4-volt sensitivity;
    26-dB gain at 2.83-volt sensitivity.
    Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
    AC Line Current,
    100 Volts: 11.4 A;
    120 Volts: 9.5 A;
    230-240 Volts: 5.0 A;
    At Idle: All amps draw no more than 90 watts.
    AC Line Connector: NEMA 5-15P (15 A).
    Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
    I need a photo cell that will handle an 18 amp load.
    i didn't find one. i recommend a relay circuit. use low current to switch high current.
    Dec 16, 2008 | Intermatic K4221C Photo Cell Control 120 V...
    Low voltage only or can timer be used for 110 v
    1 hp= 750 watts
    125 vac = 125 volts alternating current, wall outlets
    5 amp= 5amps
    125vac x 5amps= 625 watts
    a timer is a switch with a clock on it. just like a switch in a lamp cord.
    Dec 12, 2008 | Hardware & Accessories
    Electrical wiring for 120/208 service as opposed to 120/240 service
    Your machine requires 208-240 volts to operate with each leg being about 120 volts. Move refrigerators are 120 volts so even though you have 20 amps you probably only have 120 volts.
    You can go to the Bunn website (bunnomatic.com) click on Commercial then on Publications then Illustrated Parts and Service manuals and download the manual for your machine that shows how the wiring hooks up in the machine and the type of cord the machine requires to handle the voltage.
    The plug you need must match the receptacle in the wall and there are numerous 220volt plugs and receptacles on the market. Don't get a dryer plug instead try for a twist lock as they are more reliable.
    Oct 21, 2008 | Bunn CDBCF 35 Coffee Maker
    Refrigerators Logo
    291 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
