Question about Epson PhotoPC 850Z Digital Camera
Tiffen 2X teleconvertor telephoto lens
I just receved my Tiffen 2X teleconvertor telephoto lens add on for my 850Z. The camera looks pretty cool with this lens screwed onto it. The pictures look very good also. Frankly, I am surprised. I thought the camera would have a problem with the image quality. I guess Tiffen and Epson worked on this and it came out right.
    Master:
  • 542 Answers
I was testing the new Kenko 2x teleconverter I just got. Seems to work, but only at full zoom. But I left the epson supplied adapter ring on when I turned the camera off, and it interferred with the lens cover, and jammed it. It's a 4 leaf shutter assembly, and mine is screwed up so it won't open or close. Needless to say I'm kind of unhappy. I've heard Epson service is good, guess I'm about to find out. If you use the adapter, take it off when you turn the camera on or off!
Posted on Sep 13, 2005
I have a Nikon cool pix l320 I have a vivitar telephoto lens on it and when I zoom half way it says to take off the lens cover Plus when I look into the camera it's like looking through a tunnel
Now you know why Nikon telephoto lenses are so expensive and you realise why Vivitar lenses are so cheap. The Vivitar lens is not made for the Nikon, it just fits.
Nikon lenses work as part of the camera itself, not as a screw on accessory.
Dec 31, 2015 | Nikon Cameras
How do i attach the my zeikos 52mm HD Dslr MC AF 2x telephoto lens to my nikon d90?
You don't. The Zeikos attaches to the front of lens with a 52mm filter thread, which then attaches to the D90. If you have the 18-55mm lens, for example, this will fit onto the front of that lens, effectively converting it to a 36-110mm lens. If you have the 18-105mm lens, this won't fit onto it.
This device is really intended for use with cameras that don't have interchangeable lenses. With your D90, you're much better off using another lens instead of putting this onto the front of another lens.
Feb 13, 2012 | Zeikos ZE2X52B 52mm 2X Telephoto Lens
I purchased a Vivitar 2.2x lens for my Lumix DMC FZ18 camera & I'm getting a lot of distortion. Suggestions?
It's a cheap(ish) generic screw on lens multiplier and so compatibility with anything it's screwed onto is a matter of pot-luck, especially as the conversion factor is so high.
There is nothing you can do, other than to try alternative brands (preferably not exceeding 1.4x) or to obtain the expensive Panasonic version which is designed to be compatible with your camera. Even the official product will produce some distortion (usually barrel distortion) and most likely a fair bit of chromatic aberration. It's just usually less adverse than with the generic products.
Jun 18, 2011 | Zeikos ZE2X58B 58mm 2X Telephoto Lens
Can you change or add a diffrent lens to a cannon powershot S5IS
Yes you can. But you have to visit a canon service center and order them to your lense.
Jan 29, 2010 | Canon PowerShot S2 IS Digital Camera
I have a Canon Powershot S3IS and I recently purchased a 2x telephoto lens. When I use the telephoto lens and try to extend the distance as far as it will go, the camera shuts off and says lens error...
Did you tell the camera that you are using an external/additional lens? You have to specify it somewhere in the menu, the camera gives you some options (the lens model numbers) and you need to match it with your lens' model number.
Sep 30, 2009 | Canon PowerShot S3 IS Digital Camera
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Epson 3000Z in "sports" mode
With the telephote lens, I am assuming that the camera is a bit more sensitive to any form of camera shake. My suggestion, when using the telephoto lens, is to manually set the shutter speed to its fastest setting (that, or set it to "sports mode"). Also, experiment with the telephote lens using your tripod. Set the camera up on a table and use the timer so that the camera will snap the image automatically. See if the picture is still blurry. If you don't have a tripod, just place it flat on the table.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Epson PhotoPC 850Z Digital Camera Logo
59 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
