Question about Dell Latitude C610 Notebook
Dell C610 won't power up
I understand you had the same problem. Press power button, get all the leds for about 3 seconds, then powers down. No fan, disk, or screen activity during the 3 seconds. Did you ever get a solution? Thanks. Ron
  • ron6962 Sep 04, 2008
    Thanks for the input. I had already tried all the things you suggested, but tried them again with the same results. I suspect it is the motherboard, and was curious what the result was with your same problem. I have not disassembled the laptop yet (but now plan to) to check out the processor fan. Do you suppose a dead fan would give these symptoms? Thanks again.
    OK....thanks. It appears my next step is to repair or replace the motherboard. I appreciate your advice.
    Genius:
  • 2,028 Answers
There are three things that generally cause this on the Dell systems. The two most common are the battery and the memory. Start by removing the battery and powering on the adapter only. Then remove the memory and try each chip one at a time in each slot. If neither of these work, then the problem is most likely a failed component in the power management system on the motherboard. I've dealt with many of these models that have a fialed PM system, and have found that motherboard replacement is the best option, and in some cases the only option. You can have a shop take a look at it, but you will probably get the same answer.
Posted on Sep 04, 2008
  • Ryan Rogers
    Ryan Rogers Sep 04, 2008
    No, there's no way that a fan will cause this, and generally a processor won't cause this. If the fan were bad, it would simply overheat and shut down, and when a processor fails, you won't get anything, no lights, nothing. Since you've tried the suggestions, the only thing left is the power management system on the board.
Dell PowerEdge 2300 Server won't boot
To power off using the power button, press and hold in for more than four seconds.
However this is not solving your problem of not booting, needs some more information. Such as Beeping noises, number and length of beeps. Or any LED.s flashing?
Aug 16, 2012 | Dell PowerEdge 2300 Server
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Dell c610 will not turn on
Forgeet the CMOS battery, worthless exercise. Most likely from what you describe it is a bad motherboard, and on a system that old I'd say replace not repair. If you want to fix it, mothebroards are $50 to 100 for that model on EBay
Jun 03, 2009 | Dell Latitude C610 Notebook
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
Feb 24, 2009 | Dell 1720dn Laser Printer
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
Dell Latitude C610 Laptop won't turn on
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Dell Latitude C610 Notebook Logo
193 people viewed this question
Alun Cox
