I found this video from Keurig that shows how to descale the Keurig coffee maker.
http://www.keurig.com/how-to-descale-your-keurig-brewer
You can also try a electric/battery toothbrush to clean the filter below the reservior when you remove it.
this sounds crazy but put ur mouth on the clear tube that draws the water...you have to take the resevoir off first of course,,,but blow into the tube and clear it...then descale
Go to Bath Bed & Beyond buy Clean Cup for $7.99 use like you would a K-cup. Use twice. Then take out the Clean Cup pod, throw it away. Run clean water twice you Keurig should work.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sometimes the descaling sets off another whole set of problems...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Check out this tip about how to
descale your Keurig coffee brewer
How
to Descale your Keurig Coffee Brewer
heatman101
Yes, it may take more then one time...
How
heatman101
