Question about Dryers
Kitchen aid clothes dryer
The dryer will not stop running when I open the door. The light is also out.
The door switch is likely stuck or jammed by some piece of material or lint build-up. you need to locate the switch, clear the debris away and make sure that the door pin is the only thing that pushes it in.
Posted on Sep 02, 2008
Kitchenaid prestige dryer will not tumble
I fixed one that would not run last Halloween. A Kenmore very similar to a kitchen-aid dryer:
4 Wheel dryer DE-mystatified
Jul 08, 2012 | Dryers
I have a kitchen aid model keys777ezo and does not dry .. if I open the door and hold the door interlock closed and start the dryer I smell something like a heating coil but cannot see any glow from the...
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Feb 19, 2012 | KitchenAid KEYS850LQ Electric Dryer
My dryer, Kitchen Aid KEYS850LQ does not cool down! The buzzer goes off, I open the door to remove clothes, and they are so hot I can hardly touch them!!! The dryer is only 6 years old - it never has...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | KitchenAid KEYS850LQ Electric Dryer
I was using the "dry" cycle and noticed the dryer stopped after 10 minutes. When I opened the door, very light smoky/steamy stuff was coming out the door and there was a slight burning smell. Now, it...
here are two sites, i would say the vent is clogged and that the thermo switch on the motor tripped but I am not an expert, just cheap charlie:
http://www.home-appliance-kitchen-aids.com/dryer-repair.html
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
I prefer the last site, but that's just me. hope this helps Tim
Oct 17, 2010 | Asko T780 Dryer
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
Machine thinks door is open and won't run a cycle!!!!!!!!!!!!!!!!
There is a catch latch on your dryer door and that may be softening up when the dryer gets warm and the clothes tumbling against the door is enough to push the door out to the point that it thinks it is open. Try this exersize... The next time you wash clothes place a chair sideways against the doon with your clothes basket on it and see it it completes the cycle If it does then your door latch and actuating arm / post need replaced.
Jan 13, 2010 | Dryers
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Gas clothes dryer not drying clothes
could be an ignightor problem reply and we can talk
Jan 03, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
