Question about Mitsubishi WS-65809 65" Rear Projection Television
Green Flashing Light
We moved our Television to another area of the living area, and now all we get is a green flashing light that wont stop to power up the TV.., could you please help fix this issue
  • Anonymous Sep 11, 2008
    i have the same problem. can anyone help us?
  • 3 Answers
There could be a variety of problems:
1- CHECK FOR 12 VOLTS DC (AC-OFF DETECT) AT PIN 3 OF PC9A21 IF MISSING REPLACE PC9A21 PART # 268P058020 ON THE POWER PCB. 2. SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR OPEN L902 PART # 351P155010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB. 2- SHORT DETECT SHUTDOWN (PIN 13 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 M. 3- CHECK FOR BAD CAPACITORS IN DM MODULE. 4- CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 5- SUSPECT SHORTED WINDINGS OF T5A31 PART # 349P216010 ON THE MAIN PCB. 6- SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 7- SHORTED HORIZONTAL OUTPUT TRANSISTOR. 8- COOLENT HAS LEAKED ON THE MAIN BOARD FROM THE CRT'S AND HAS DAMAGED THE MAIN BOARD BEYOND REPAIR. also if the 24 volt B+ and or B- Is missing from the convergence ICs, change both convergence ICs as well as the defective pico fuse in the power supply. This is not a quicky type of repair most likely. These are a few of my notes on this Set from me and a few of my buds in the buisness. Good Luck and let us know how you made out with this set.
Posted on Sep 12, 2008
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Wont power up , green indactor light wont stop flashing
You have four capacitors bad on the "DM" module in the unit. I recommend you get a tech to do this repair. This is due to the complexity of accessing the DM module. A qualified tech can do this repair in under an hour. You can find a tech in your area by inputting your zip code on the home page of this website. Let me know if I can be of further assistance
Jan 11, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
