HDTV Is ilo P42BSMT-U32 HD?
  • 520 Answers
Call Tatung 800 927 7880 and find out. They made it.
Posted on Sep 02, 2008
I need to find out how to hook up my ilo technologies plasma display Model No.: P42BSMT
Here's the original owner's manual for your TV!
P42BSMT Owner's Manual
https://www.remotes.com/v/vspfiles/files/owners-manuals/P42BSMT-TATUNG.pdf
It's worth noting that while the TV in this manual is branded as Tatung, it is the same as your iLo television.
Jan 10, 2017 | iLO Televison & Video
ILO 42 plasma P42BSMT-32 am upgrading satellite service to HD is this tv HD compatiable no HTMI port
You can get 720p or 1080i " fake 1080 " through the RGB component inputs, But you will not get 1080p true 1080 res. But, this TV is only 720p anyway. But,it will still make a big difference in the pict. up-grading. And having the new HD box when you get new your new service now,will save you $100 from needing to buy a HD box later if you have a new TV with the HDMI. As DirecTV will give you the HD boxes free with new service. But,charge later if you have up-grade from a standard box. No sure how Dish network does tho. But, not have had too many customers happy with Dish. DirecTV is the way to go. And the signal during the rain is so much more problem free.
Apr 26, 2014 | Televison & Video
Code for remote P42BSMT-U32
These are the universal remote codes for Tatung TV.
0081 0198 0003
Jun 28, 2012 | Televison & Video
My ilo hdtv doesn't have a cable hook up
Going to have to connect (no coax fitting means it is a monitor with no tuner) via one of the rear audio/video inputs with a box that has those outputs on it.
HD is almost always connected in this way.
May 02, 2012 | iLO IWT3206 TV
Does the tatung have HD?
The Tatung P42BSMT is HDTV capable.
Jan 09, 2011 | Tatung P42BSMT Television
Remote control code for Tatung P42BSMT
?????????????? Tatung Plasma TV P42BSMT ????????
Tel.086 0687155
Jun 29, 2010 | Tatung P42BSMT Television
Power Cable Replacement
Try ebay. If unsuccessful you may have to convert the plug on your set to a standard one that will work with a normal standard wire.
Jul 28, 2017 | iLO V27DMBX Television
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
