Question about Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive
My External hard drive is not responding
I think my drivers for my Acomdata - HD500LJHE5-72 External Hard Drive has stop working and is not even loading. I do not have the disc, is there anything that I can do to get it back working?
  • 2 more comments
  • dlbecker Dec 03, 2008
    I went to bed with my external HD working and when I woke up my computer could not recognize it. I tried switching firewire cables, plugging it into different outlets to no avail. I hear the noise that my PC is recognizing that something is being connected and disconnected. I have all my music files, as well as all my important school and work files on this HD. How can I recover this data? Will this thing ever work again??
  • markanels Jan 01, 2009
    Help!!!! 50 mb drive... simply not recognized by my computer... tried connecting to another windows PC and an Apple Mac book... the blue light is on but no one is home!
    This drive worked fine for a year... then suddenly..... it won't get recognized!!!!
  • oprunner Jan 03, 2009
    I have the exact problem. Basically when I plug it into any computer and trun on nothing happens. Surfaced in mid 2008 so I went to Acomdata website and logged a ticket but got zero response. Then I did it again. Now today (3 Jan 2009) thier website isnt even up. Is acomdata even a real company? Did we get duped?
  • maultz Jan 05, 2009
    exact same problem
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    Trouble with my Acomdata external hard drive and my mac
    Unfortunately it seems that Acomdata is no more on businness.
    In order to get support you can try writing an email to techsupport@acomdata.com
    Feb 04, 2013 | Acomdata Computers & Internet
    I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
    You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
    Hope this helps!
    Regards,
    Joe
    Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    Acomdata 250 external (SATA) hard drive not showing up on desktop
    be safe
    go on line to acomdata web site and down load the driver from there
    Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
    I can't access my external acomdata hard drive.
    when you first plug in the external hard drive
    windows should pick up on it, it must be on.
    then go to start,settings,control panel,classic view on left, system on bottom,hardware tab,device manager,look for any yellow !! marks,you may need the driver for this, in order for it to pick up on the ext. hard drive
    Jul 19, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
    Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
    how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
    Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
    If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
    Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
    Jul 14, 2008 | Computers & Internet
    Installing old drive into new drive
    If the problem is in the controller inside the case which in 99 percent of the times it is, This will certainly fix your problem. The MTBF(mean time between failure) of harddrives is 100,000 hours of operation. Also, any external case can be used that matches your hard drives specs...size, IDE, SATA ect...
    Hope this helps you,
    George
    Jun 22, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
    Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive Logo
    730 people viewed this question
    Top Acomdata Computers & Internet Experts
    Jerry Umali
    terminalcon
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
