Question about Dell Inspiron 700M Notebook
Screen goes out or shrinks to a mm line with rainbow color at top of screen
Dell has worked on it several times. After a small time period of leaving the laptop alone, the screen either goes out where I would have to restart it or the screen will shrink to one line of about a millimeter and will be at the top of the screen. Dell has replaced the screen and it has had no effect. It has been erased and reloaded several times.
What could be the issue.
    Genius:
  • 2,028 Answers
I'm going to say that this is a problem with the video card. The video card controls the screen, and the screen wouldn't do this, so replacing the screen won't have any affect on the problem. As you have noticed. Have Dell replace the video card, and everything will work properly. I'm also going to say you will most likely have to be a bit forceful with Dell. Tell them you had it diagnosed by a tech, don't tell them it was on line. They know, or should know, that the screen won't cause this problem, and that the video card is the issue, but the video card is integrated into the motherboard, and motherboard replacement is the only viable solution. Sounds to me like they're trying to get out cheap.
Posted on Sep 01, 2008
Vizio 46lfhdtv20a verticle rainbow line down the screen. picture start playing and after a while the color line cover the screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 29, 2016 | Vizio VO47L 47 in. LCD TV
Dell Inspiron D530 - Screen Malfunction - Rainbow colors?
Reseat the display cable (under the keyboard) and while you have the lcd hinge cover off, inspect the cable where is goes thru the hinge assembly for chafing and possible broken wires.
If reseating doesn't help, RUN DIAGS
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=E3FE44D4AAF58D13E0301E0A5517246B&doclang=en#1
If they fail then replacing the LCD display cable and or the LCD would be next.
Dec 09, 2009 | Dell Latitude D530 Notebook
My screen has rainbow lines on it after i dropped it? half iof the screen is white with rainbow colored lines on it, ive turned it off and back oin several times, and its still like that. How can i fix...
You can't fix this by yourself. Your LCD screen is officially broken. If you have a service plan, you can generally get the phone exchanged for a nominal fee.
Jun 10, 2009 | RIM BlackBerry Pearl 8100
Green Screen - LG 42PX5D
hello, seems to be panel trouble, plasma and lcd main panels are not fixable, the color green isnt a good sign or it is a symptom of the panel being bad,
i know its a bad diagnosis but this is true with this color on a panel.
if it is a worth while set and you want to restore it theres few options one is replacement trough your waranty
the another is having the screen replaced by a service center this is to costly and rarely done by them they would advise you to get another set. at a retail price a screen replacement is as much or even more than the tv itself.
finally you may search online listings for a servicable tv same model and exchange the parts .
the third option is the best if your waranty is expired.
good luck hope this helps
happy holidays.
Dec 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
27V412T turns self off
You have a bad vertical deflection IC and/or bad capacitors in the vertical circuit. The parts are inexpensive and can easily be replace by a service technitian.
Mar 14, 2008 | RCA 27V520T 27" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Monitor (Dell 1701FP) flickers, flashes and goes black
Just to check - when the screen is black- can you see any image- in its un-illuminated state. To do this look sideways along the screen not straight at it. I suspect this is an inverter problem. Whether or not this is repairable I know not- depending on your local repair facilities Perhaps DELL can suggest a local agent.
May 16, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Dell Inspiron 700M Notebook Logo
70 people viewed this question
Alun Cox
