Question about Airlink (APSUSB2) Print Server
How to set up Airlink printer server ASPUSB2 - Airlink (APSUSB2) Print Server
I purchased the Airlink 430W on Friday. After
http://airlink101.com/download/download_links/q-ar430w.pdf
May 12, 2010 | Airlink AR430W Wireless Router
Airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Jul 08, 2009 | Airlink AR430W Wireless Router
I'd like to use my Airlink 101 802.11g wireless router as an access point in my home office. Is that possible?
if it is a wireless router (no modem functions), then you would need to have it connected to your modem so you could set it up as your access point.
Jun 05, 2009 | Airlink AR430W Wireless Router
I need To install on Mac
Try the software located at this page:
http://www.airlink101.com/support/index.php?cmd=files&id=32
If PS stands for Postscript as I think it does, then these will be compatible with Mac. Try the PS Wizard software, the 3rd down in the list.
Please rate, Thanks!
Jan 19, 2009 | Airlink (APSUSB2) Print Server
Hi, I have an airlink print server connect to a LAN wit both Wix XP and MAc 10.3 machines. The Win machine work fin e with soft ware and a IP connection, but when I try to print IPP from the MACs I get a...
Make sure you have your IP addresses properly configured. An IPv4 address is made up of four numbers fro 0 to 255 (eight-bit binary numbers) separated by periods, for example, 192.168.1.1. The first three numbers are the subnet address; for small networks, the factory default is usually 192.168.1. Every computer, router, print server, etc., on the subnet must have the same subnet address to communicate directly. (Generally, there is only one router on a subnet). Also, verify that everybody has the same subnet mask (usually 255.255.255.255).
Client computers on a network usually have addresses assigned automatically by the router using DHCP. Print servers and the router should have their addresses assigned manually so the other units on the network can find them at the same place after a restart. Routers typically get address 0 or 1 (e. g., 192.168.1.1). It is a good idea to configure the router to reserve the print server address (or make sure it is in the block of reserved addresses so it is never assigned to anything else since that would cause a conflict (server busy?). Use a high number for the print server address (e. g.,200-255, as in 192.168.1.254, which is the default address for the Airlink 101). On Windows, type <Windows-r> to get the run program <filename> dialog, then type "cmd" to get a command line window. Type "ipconfig /all" to read the IP address information. Type "ipconfig /renew" to get a new address. For information on using ipconfig to modify IP address parameters, type "ipconfig /?"
On each Mac, open the Network control panel, select IPv4, click on "Advanced", then click on "Renew IP lease." Verify that the computer gets an IP address in the correct range from the router, for example, IP address 192.168.1.14, subnet mask 255.255.255.255, default gateway 192.168.1.1. The DNS server will most likely be on a different subnet out on the Internet.
Now you should be able to find the print server using Rendezvous, LPR printiving via IP or AppleTalk.
http://www.airlink101.com/download_links/apsusb1_manual.pdf
The manual linked here is a bit old, but it covers Mac OS 10.3 configuration for a Airlink server. Your server may be a different model, but operation is probably similar unless AppleTalk and other older protocols have been removed.
Nov 19, 2017 | Computers & Internet
Airlink (APSUSB2) Print Server Logo
136 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
