Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Lens Problem I just bought an Olympus C-8080. While switching the camera on there are some 4 to 5 light pixels on the display (lcd monitor on the back of the camera), even when directing the camera into the dark. It is not really a problem now, but do you also have this problem with your LCD monitor? What if they become more?
    Sergeant:
  • 255 Answers
Dead pixels are a nightmare of every LCD screen. There is no way to avoid them - you can just hope they never happen to you. There is no pattern to how they appear and when, but the ones you have will stay for ever. If they bother you right now, send the camera for repair while it's still on warranty - otherwise you can ignore them - they are not an indication of future problems.
Posted on Sep 13, 2005
My olympus sp800uz lcd display square image only the lcd is not full how can i solve this
I suppose that you mean that the image you see is in 4:3 ratio. That is quite normal, because the default settings are 4:3. However, if you want widescreen (16:9 full LCD) images, just change the Image Size setting in the menu to 16:9 L (4288x2416 pixels) or 16:9 S (1920x1080 pixels). See the user manual page 30.
Oct 15, 2010 | Olympus SP800UZ Digital Camera
Olympus Stylus 1030SW. The LCD monitor is pixelated. The pictures that are taken with the camera are crisp and perfect. When reviewed on the camera, they are very pixelated. When searching through...
You can try to reset the camera to factory defaults to see if this improves the monitor. You go to Menu and then left arrow to Reset and press Ok. Up arrow to Yes and Press ok this will put the camera back in factory default settings. If the screen still shows as pixelated, you might try to do a function of the camera called Pixel Mapping. Go to Menu and then right arrow to Setup then down arrow to Pixel Mapping - right arrow to Start and then the camera will try to repair the CCD processing chip inside the camera. If after this completes if the screen is still pixelated, then you want to send it to an Olympus service center for repair.
Aug 30, 2008 | Olympus Cameras
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Oct 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
LCD Screen jumps around after 2 minutes of use. It does not effect the end result though. I also notice an opaque pixel wave that cuts across the screen at all times. This started happening about 2 months...
When you say the screen jumps around -I assume you mean the image not the actual screen it self. There are so many model out there it is impossible to be definitive. Try both of these 1. check the manual out and see if there is a 'Reset to factory setting' mode If not check out the Olympus Technical Help team at the Olympus web site. I have heard it said that the U.S. Olympus are not very helpful ,so if you can, try to locate Olympus Europe [based in Germany] I is almost certainly not a 'repair option,
Jun 10, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Olympus C-8080 LCD wont work
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Apr 07, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Lens cap test...
Switch on camera into Shutter mode. Put lenscap over lens or block it so you get a black LCD. Have a look at that first. Only a general indication but if there ARE any bad pixels on the LCD they will be visible as coloured dots. Not too important as THAT doesn't affect the pic but personally I would not put up with it - took one back for exchange for that reason .. who wants to look at spots. The CCD is the real one to look for. With lens still blanked off to a black screen set the shutter at 2 secs, take a pic then set at 4 secs, take another pic. You won't see much on the LCD so you should download those tests to your editior - Paintshop Pro, Photoshop or whatever. THEN you get a much bigger pic (black) to look at. You'll probably find at least one or two little spots, almost inevitable with many, but you should NOT get many and also very noticeably bad spots. If so , complain and exchange.
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
48 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
