Question about Olympus Camedia C-770 Digital Camera
Out of focus shots at night
Hi, I have just purchased the olympus C-770 and while it takes great shots during the day at night when I try the shots look out of focus.Its as if the shutter speed is not fast enough and causes blurr.This is when taking with flash. Any help would be a great help.
    Sergeant:
  • 255 Answers
The C770 uses an Autofocus TTL system (contrast detection) so day or night if you dont have good contrast it wont focus properly. You could try the camera in night mode on a tripod. This camera is just not good for low contrast/low light situations. If there is a small area of light in the scene/person try using spot autofocus. Finally this is an ultrazoom 10x camera. Back off on the zoom all the way. The more zoom you have the less light you are seeing/collecting. Its a fun camera but with limitations and you just have to get used to them. Good luck
Posted on Sep 13, 2005
    Sergeant:
  • 255 Answers
First, check to see if you're in auto or program mode, as opposed to manual or possibly even aperture priority (if it supports it). Typically, auto or program mode sets your shutter speed to around 1/60th of a second, which is usually good enough to hand-hold a flash shot without blur. The camera should emit enough flash - within its range, of course - to get a good exposure. You typically won't get a good flash shot if your subject is more than 10-12 feet away. If you want, you should be able to go back and look at the way your camera was set for each shot with a program like Photoshop or Elements. That information is stored as "EXIF" data, and if you select a file in Photoshop CS' file manager for example, you should be able to see what the shutter speed was on any given shot. Let's suppose you look at some old, blurry night-shots - the EXIF data, that is - that should've turned out OK and your shutter speed and everything look fine. At that point, I'd try taking some flash photographs using a tripod at night which would eliminate camera-shake as a possible cause of the blurry shots. I suspect that the likely cause was your camera wasn't in the correct mode though and once you get that squared away, it'll be OK. Good luck!
Someone help me out, I have the Olympus fe 4000 and I hate it. It takes forever to focus for a picture. I have to have it on iAuto to take any sort of shot and even then it still is not great quality or...
1. Set the AF (focus) mode SPOT, if available.
2. If your camera has settings for (image) compression, set it to FINE.
3. Set the Image size to a (higher) wanted resolution.
Aug 22, 2011 | Olympus FE-4000 Digital Camera
Sometimes when taking photos the photos are fine and sometimes they are really blurry. Why is this haening?
this may not be the camera but the lighting situation of the photo. or how the camera is held this also happens on film cameras.
if the subject is not well lit or the flash fails to go off or is blocked by a finger then the shutter stays open longer to get enough light to see the image. if the auto focus apature is blocked it will not focus on the subject and will come out out of focus
if the camera moves in the time that the shot is taken it will blur.
if the blufing is from left to right or up and down it means the camer moved during the shot.
if the whole picture is blured all over this looks like being out of focus and not due to movement.
check your IOS speed setting for your camera if it is set low then the camera will needs a lot of light or show shutter speed to capture an image. set it to auto or higher than 100 is best for most situation
if the camera is set to manual an not automatic the camera will only shoot at the set shutter speed and this can cause bluring.
try some test shots on a table or a tripod and take several shots in automatic mode with auto focus on take them one after the other they should all be the same but if one is blurred then there is a problem with the metering of your camera if they are all fine they it is due to camera shake when the picture was taken.
a few tips.
hold the camera to the eye with the elbows against the side of the body.
in dark lit places try to use a tripod or some other support or external light source or flash.
ensure the fingers are away from the auto focus apature the lens and the flash light.
i hope this was helpful
Dec 12, 2010 | Olympus Stylus 770 SW Digital Camera
My olympus stylus 770 SW digital camera pictures during day time are so bright..what should i do?
Lower the ISO sensitivity to around 200 or 400.
That's like film speed... the lower the ISO the less sensitive it is to light.
[Menu]
[Sensitivity]
(down arrow) to 200 or 400...
What is is set on? 3200??
Sep 30, 2009 | Olympus Stylus 770 SW Digital Camera
To much light exposure when taking photos
Go to menu and try to setup the factory settings it may be a setting that is doing that.
Hope it helps
Jun 25, 2009 | Olympus Camedia C-770 Digital Camera
Olympus mju850 - fine at night but hugely overexposed in daylight
it is ur luck if camera still works in indoor pics then only take indoor pics but the pics are not crisp and clear they need to be there will be dis colored and scratchy but u can try see which are better i think pics without flash with adequate light will be better one's
i am here to help u in this if u like
Apr 08, 2009 | Olympus mju 740 Digital Camera
Broken or something would like to now what to do
Hi. You have to take your camera into a repair shop.
Rob
Mar 05, 2009 | Olympus Stylus 770 SW Digital Camera
Night shots using flash giving a bluish color effect.
try reset the camera back to camera defaults by putting dial on p, menu, custom reset
May 16, 2008 | Olympus EVOLT E-500 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
LB-01 CR-V3 lithium Batteries
The Olympus CR-V3 lithium batteries will provide approximately 500 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are not rechargeable.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Ni-MH Batteries
The Olympus Ni-MH batteries will provide approximately 200 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are also rechargeable.
Olympus Camedia C-770 Digital Camera Logo
75 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
