Question about Denon AVR-2801 Receiver
Subwoofer for Denon AVR-2801
I have a AVR-2801 connected to a Bose Accoustimass 7 surround sound system. I would like to add a subwoofer. What would be a good match and be cost effective?
  • goldyzygo501 Mar 15, 2009
    I have a Denon AVR-486 using Bose speakers, I would like to add a subwolfer, does anyone know what would be a good match, & produce wonderful powerful bass, without breaking my pocket book???
    Thanks
    goldyzygo501@msn.com
  • 395 Answers
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Posted on Jan 13, 2008
  • 3422 Answers
SOURCE: Denon AV Surround Receiver AVR-486 w/DSW-76 Subwoofer
HI,
Disconnect all of your speakers(subwoofers)then turn the receiver on. If it still does it, then bring it into service. If not, that you have a short somewhere probably the main board and there are no home remedies for this.
Goodluck..
Posted on Aug 03, 2008
  • 92 Answers
SOURCE: MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Posted on May 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Posted on Dec 07, 2009
Testimonial: "Thank you sir; your quick response is highly appreciated. I returned Denon and am considering DVDO Edge. Regret running Bose wires @ construction?"
SOURCE: i need help configuring my denon avr 2801
Just moved and got mine hooked up last week. Was working great and now I can't get anything. The reassuring "click" I've always heard when I switch between inputs is gone. Anyway enough about my issue, what specifically are you having trouble with?
Posted on Sep 14, 2010
Bose 3-2-1 system subwoofer connect to denon avr
The subwoofer is not designed to be connected to a non-Bose amplifier.
Jun 07, 2012 | Bose Audio Players & Recorders
Our denon 1708 only play on stereo mode,no sound when it select on 7 channel.. crackling on dolby. what is the problem on that receiver? please help
The surround sound outputs outputs ic's in the remainder of the system have opened, or there is a short in the speaker wiring, check to make sure that is not the case, if okay! you will need a repairman to assess the situation.
Mar 31, 2012 | Denon AVR-1708 Receiver
I have a Denon AVR-2801 that I have owned for many years with almost no problems. I have 5 speakers and a subwoofer connected to it - the speakers are connected through the wire inputs on the back and the...
Maybe start with speaker test tones to verify the hardware instead of messing with live audio modes.
http://www.retrevo.com/support/Denon-AVR-2801-Receivers-manual/id/363bh831/t/2/
BTW: the powered subwoofer is supposed to be driven by the 'Subwoofer' Pre-Out.
What input are you using that allows audio when you select EXT IN AND the other modes? That is a specialized analog input for 5.1 analog equipment ONLY. (Page 32)
Aug 14, 2011 | Denon AVR-2801 Receiver
I need help configuring my denon avr 2801 receiver, im trying to hook it up to my tv for surround sound
Sep 06, 2010 | Denon AVR-2801 Receiver
Dec 05, 2009 | Audio Players & Recorders
How do i connect my denon RC7000CI to denon amp. 2801
I cannot access the setup menu on the unit display or via the s-video monitor out -- everything was working fine a few days ago. I have reset micro, unplugged all night, reset again, and still cannot get to the menu in order to correct connections, esp for digital. My problem is on the avr5600 but seems like this happens on many of the denon units
Mar 03, 2009 | Denon AVR-2801 Receiver
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
Denon AVR-2801 Receiver Logo
94 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
