Question about Galaxy Radios DX-33HML 40-Channels Base CB Radio
CHANNELS MOVED OR MISSING
I HAVE A GALAXY 33 THAT HAS MOST OF CHANNELS MIXED UP OR GONE. FOR EXAMPLE CHANNEL 19 AND 20 ARE THE SAME. EVERY ONE SAYS IT SOUNDS GOOD ON ALL CHANNELS THAT WORK. WHAT COULD BE MY PROBLEM? I HAVE TAKEN TO SEVERAL CB SHOPS WITH NO LUCK.
  • 3,018 Answers
  • Yes, the PCB band selector board. That's exactly what's wrong. You can replace this yourself. The board is held on the side of the radio with one little screw and has 3 or 4 connectors that plug into it. Maycomm is where I get my new Galaxy parts from http://maycomcomm.com/
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Posted on Oct 08, 2011
  • 90 Answers
There's a problem on the band selector board, either a bad connection or a bad diode. If you can't find a local reliable shop call ours at 973-831-5900 between 10-6 Eastern, 10-3 on Saturdays.
Posted on Sep 05, 2008
Channels 5 &50 are missing on my t/v
You cable company may have moved the channels. Check their on-line channel lineup.
Feb 28, 2015 | Computers & Internet
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
3 channels missing
Those channels all are related in the same tuning band that most tuners have----suspect you have a bad tuner--unless you are using a box in which case suspect the box is the issue.
If the tuner is the problem there are ways around that--used a cable box set to the rear inputs (audio/video) on your set and bypass the problem.
Jun 01, 2012 | Westinghouse LTV-27w7 7 in. LCD HDTV
Need to kwon the numbers for the galaxy santurn base radio to repair it cause the one it has dont belong to it.
What are you needing can you explain more detail. And all the exports base radios are the same schematic as. Are the mobiles. The galaxy 33 and gal 99 are the same radio just the 33 doesn't have the ssb parts
Mar 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
Unable to get cable channels past channel 33.
Your problem is likely not your TV. It's due to the signal being provided by your cable company. I suggest that you contact the cable service provider which you are using and advise them of the problem.
Mar 18, 2017 | Spectra KT2313 Combo
Channels
try to rescan the channel by menu , installtion , manual scan then press ok should find the channel but may need to go though all channels as it may have moved
Oct 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
Galaxy Radios DX-33HML 40-Channels Base CB Radio Logo
179 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
