Question about Vacuums
Filter I need to know if the filter is washable in a Hover Elite Auto Rewind Vacuum
  • 120 Answers
I wouldnt, it usually soaks the dirt into the filter, try using a shop vac with a dust brush attachment that is the easist and cleanist way to do it.
Posted on Sep 18, 2008
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
Possible problem with thermal indicator?
Remove all filters and the dust bin and leave the vacuum motor run for a while. If it does not shut off it may mean your filters are clogged and need replaced. Even washable filters should be replaced frequently because they become clogged and restrict the airflow. You can't always tell if a filter is clogged by looking at it.
Jan 26, 2014 | Hoover U5507900 Elite Rewind Bagless...
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
I have a Hoover Elite Rewind vacuum. Actually,this is my second one. However, after about 4 months of use, it emits a "sour" smell when I'm using it. I empty the cannister before each use and clean out the...
does it smell like an electrical burning odor? could very possibly be the motor going bad already. ive seen it happen. but if not try freshwave odor absorbing pearls. i carry it in my store and we do have shipping. Truly the only thing you should use to get rid of odors in a bagless vacuum, it wont clog your filters
Jan 03, 2010 | Hoover U5507900 Elite Rewind Bagless...
My HooverDeluxe Elite Rewind became extra loud
If the belt is really worn it can cause that. I wold try changing the belt if you haven't recently. Here are the belts you need:
Hoover Elite Rewind Belts
Nov 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Sep 23, 2009 | Hoover U5507900 Elite Rewind Bagless...
Can I wash filter in water
I haven't seen one, do you have an air compressor? You can blow it out.
If it's plastic it should be washable, if paper--no
I use air on my Eurika.
Apr 26, 2009 | Vacuums
Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Apr 08, 2009 | Vacuums
Hover Elite Rewind I've only had this vacuum a few months and I really liked it until now. There is almost no suction from anywhere in the vacuum, and I've cleaned all the filters and rollers with my shop...
You have to clean out the hose under the bottom of the vacuum cleaner. To do this you have to remove the bottom plate the covers the brush it has about 6 screws. Also remove the brush and belt in order to thourhly clean it. I had the same issue you had. Now it works like new after cleaning this out. The sucktion power is back and it doesn't shut off on me any more. Hope that helps.
Apr 06, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
