Question about Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking
Need replacement bulb for toastmaster tlwtob6
Does anybody know were to get bulb for this oven?
  • cslaw Nov 30, 2008
    pls help, we love the toaster oven
  • adrianapigno Apr 09, 2009
    i need to replace the broiling bulb......... anyone that knows where find one and how change it?
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Tip
How I Fixed A Break
My TLWTOB6 Salton Toastmaster Lightwave broke, and I fixed it. It had still turned on the display OK and pretended to run, but neither the top nor the bottom lamps would turn on. Also, it made no clunk sound that it would usually do when turning on the lamps.
I took it apart (keep careful track of which screws go where, and there are lots of sliding tabs to put pieces together). I examined the bottom of the circuit board holding the big electronics, and saw discoloration; evidence of heat damage. I wiggled a wire near by, and its quick connect tab came off the circuit board; it hadn't been soldered right at the factory. So, I resoldered it (hope my job was done better), and put it all back together, breaking and resoldering a data cable in the process -_-
So, it works fine now, and hopefully will last a while. By the way, the web address in the manual, www.toastmaster.com, doesn't work any more, and the URL is not associated with any IP address right now. Also, there appears to be no fuse inside the toaster oven.
on Aug 17, 2010 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Manual for a Toastmaster 7094A
http://www.retrevo.com/samples/Toastmaster-Oven-manuals.html
this site should do the trick
Nov 08, 2009 | Toaster Ovens
The knob for the oven temp control broke and needs to be replaced
www.bizrate.com/toasterovens/toastmaster-cool-wall-357-toaster-oven
Mar 15, 2009 | Toaster Ovens
Manual
Toastmaster TUV48 manual
http://dl.owneriq.net/0/0adc711e-85ab-4238-a68a-19394579d13e.pdf
Mar 16, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
Halogen light heater
I have same problem Took whole unit apart found upper bulb is connected with wire that goes through out. You hve to physically take bulb out through side without electronic panel wire is connected on panel sid with actual plug. but ended up cutting wire other side. Bulb is not like regular bulb you will have to hard wire one side of it. bulb is unseperable from wire. Still looking for replacement bulb. I sure miss my toaster I believe it will probably be chaper for me to buy new toaster vs replace bulb. The bulb is nothing like I have seen before.
Nov 03, 2007 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking Logo
131 people viewed this question
Top Toastmaster Toaster Ovens Experts
Mike Cairns
Mike Cairns
Dennis Boxerman
john h
Are you a Toastmaster Toaster Oven Expert? Answer questions, earn points and help others
