Question about Energizer Rechargable Battery with Charger
Pool motor wiring
Dont know how the wires go back. have red, black and ground from motor. have red, black, white and ground coming from house. need to go into cfci duplex receptacle and on/ off flip switch.
    Problem Solver:
  • 8 Answers
First and foremost, you need to check the Motor's voltage requirements, and match it to the voltage of the GFI you have connected to the House current.
The best way to do this is to use a volt meter at the GFI receptacle. Although it's likely the voltage at your GFI receptacle is 120Volts AC, you shouldn't guess on this. If you know what circuit breaker this GFI is using to get power.... you may be able to determine the GFI's voltage if you know how to distinquish between a single pole breaker and a two pole breaker (120Volts is derived from a sigle pole breaker, 240volts from a two pole breaker-which is twice the size of a single pole breaker).
Now the Motor: Most common Pool Motors are dual winding motors, on which, the voltage requirement could be changed to match the voltage supplied. On such a motor, there's a compartment where the cord is attached. Within this compartment, there's a configuration of screws or terminal points, and a related schematic which depicts the proper connections for each of the voltage options. By following these schematics, you will know how to connect the motor based on the available voltage supplied by your GFI protected receptacle.
Posted on Mar 23, 2009
    Problem Solver:
  • 6 Answers
I assume you mean a gfci recepticle? If this is the case you need to take the black wire from the house and pigtail it to go to both the recepticle (Black / Line) and one line side screw of the switch. The white wire from the house goes directly to the line/white side of the recepticle. Also pigtail the ground to go to the green screw on the recepticle, the green screw on the switch, the green wire from the motor, and the ground screw on whatever box you're using. When you purchase the switch make sure you get a two pole switch rated for at least the amperage of the motor. The red wire from the house and the black wire from the pigtailed black will go to the two line side screws of that switch. The red and black from the motor will go to the two screws on the load side of that switch. Make sure to ground everything properly being so close to water. The cover needs to be sealed securely and I recommend the cover that has the lever to activate the switch as opposed to the little door over the switch handle. Also make sure the two breakers supplying those two circuits have a handle that turns them both off at the same time.
Posted on Nov 26, 2008
I disconnected the pump and need to know where the red black aND WHITE wires go
Hi, this is John the Hayward tech. You say the wire colors are Red, Black and White. Does not seem that the wires colors were correct from the start. Not knowing your voltage let me clarify some things. Normally if you have 115volts coming into the pump you wire colors should be Red or Black to L1 White to L2 and a green ground to the green ground screw. If you have 230volts coming into the pump the two hot leads are normally red and black with a green ground. The red and black wires go to L1 and L2 does not matter red or black. The green goes to the green ground screw.
Sep 03, 2014 | Pool & Spa
I bought a house that had an intermatic t104 running timer running the pool pump. It worked for a little while then the clock stopped turning. The manual switch still worked to turn on the pool. I...
If you only have a Black wire, White wire and a ground wire, you are only wired for 120 volts. For 240 volts you have to have two Black wires or a Black and a Red as well as a White (neutral) and a ground.
Jun 21, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Pool pump 3/4 hp wiring
I think the lug with no screw is for 110 volt? Don't know, but your 2 wires in, black and red are both hot, each one to the lugs,line 1 and 2, the bare wire gets bolted on outside of the motor and jumped to another ground somewhere, and the white wire, goes to a lug marked B?,,, check that one. I went to the web site and they want you to know if you do it wrong, no guarantee, so check out the frame number, then look up your motor and go by the label.
http://www.pool1.com/motor.asp Hope this helps.
May 05, 2010 | Smith AO Pool Pump Motor
Trying to wire jennair cook top to house wiring. Cook top has red white black and bare copper wires. House wiring has two large black wires and a some sort aluminum loosely braided 8 strand wire coming...
if you have220/240 across the house black wires put red from stove to one black then black to blackaluminum to copper should be the ground turn breakers off after you check the volts across the black and the ground make sure the ground is a ground and you will need to run a white wire back to the breaker box for the neutral then white to white
Aug 04, 2009 | Kitchen Ranges
Replacing plug on a 2 speed magnetek 1.5 hp motor
More often than not red is high and black is low. The white is the common and of course green is ground. If High and low are backwards, swap the red and black.
Jul 31, 2009 | Pool & Spa
I am trying to connect my new pool motor. I have 3 wires coming out of the box. a black one 120v a white one 120v and a copper (ground). How do I test if it has 240v? How can I connect the motor so works....
Most probable cause is that you have the black and white on the same phase, and that's why you have 120 volts from black to ground and from white to ground, but 0 across black and white. If the motor ran on 120 volts, why are you connecting it to 240?
In any event, in order to get 240 volts, move the white to a circuit breaker that is directly above or below the breaker that feed the black wire. You are supposed to use a 2 pole breaker for 240 volts anyway
Jul 23, 2009 | Pool & Spa
Pool pump wiring
O.K. MONIKA READ VERY CAREFULLY!!!!
I DON'T REALLY LIKE TO GIVE 220 VOLT WIRING OVER THE INTERNET,LET ALONE THE PHONE,but I have a good feeling that if you all replaced the seal, you have an understanding of what you are dealing with: 1st make sure all power is disconnected,Breakers too(hey I have to say this so don't take it to heart), now the two black wires are 115 volts each, and the white one is ground, now enough said, the wires going from the source, (pool house,pump room), should be one white,one red, and one green, if this is the case the black and white wires, are the ones to hook up your black wires to, it does not matter (which of your black wires) go to either the red one or black coming from the source, and if your white on the motor is your ground it should goe to the green one coming from your source, if you don't already have them,I SUGGEST, you go to home depot,or lowe's and purchase the BLUE "water tight" wire caps, they can and are a "life saver anytime electrical is used around water, they cost some, but isn't a life worth a buck or two more? remember 115 volts can kill you if your around water 220-248volts will really kill you, so please check and double check all that I have told you. make sure everyone is clear,(pet's too), and flip the breaker, and you should be in business, god bless, happy 4th, and please let me know if I can help more
Jul 03, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
May 15, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Energizer Rechargable Battery with Charger Logo
161 people viewed this question
Top Energizer Electronics - Others Experts
Carl Glas
Carl Glas
Bill Boyd
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
