Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
No picture My projection tv has no picture all of a sudden, I have direct tv and the guide still shows, and even the channel numbers but no picture, what's the problem? please help. Football season is right around the corner
  • Hitachi Master
  • 520 Answers
Reset the Directtv box. (If you don't know where the reset button is, unplug it from the electrical outlet for about 5 seconds then plug it back in.) If this doesn't work you may have to call Directtv.
Posted on Sep 01, 2008
  • 927 Answers
Good Day, Young33dm;
If you have the BOX showing OSD, (On Screen Display), the BOX is bad. Get a new box or try resetting the BOX by unplugging it for 2 to 3 minutes, then plug back into A/C source.
Good Luck, big IRISH.
My rca p52936 will not change channels. everything else seems to work.
First would be what kind of signal are you using? Direct cable to the set or what?
If only one channel does the number on screen change when you change channel but set stays on the last channel?
Also look to see if set on the front has the "Guide Plus" logo.
Jun 15, 2012 | Televison & Video
Word Component1 shows up when changing local channels
Your Direct TV box is switching between a Standard Definition channel and a High Definition channel. When this happens, the TV has to switch the display format. As the format is changing, you will briefly loss picture, the TV detects the new format, and then displays it. What you are seeing is the normal operation of the TV. It the TV did not blank the picture, you would see a broken chopped up picture during the transition. If you are familiar with the setup menu of the Direct TV box, you could change the video format settings so than it locks to the High Definition format. If you are not familiar with the Setup menu, you should contact Direct TV and ask then to walk you though this procedure. Specifically, ask them to "Help me set my Direct TV box so that it always displays in 1080i format." You pay for them for the service, they should be able to provide you with some phone support at no charge. I hope this was helpful, best wishes.
Apr 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Suddenly all of a sudden
I have a JVC AV48WPT4 48 Inches. Have perfect picture but fine retrace lines on the screen.
Can you tell me what could cause it?
Thank you.
Apr 21, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC Rear Projection
If you still can see the DirecTV guide and menu, the problem could be on your satellite receiver and not the TV. Unplug your receiver and plug it back.
If the rebooting did not work, I would suggest to swap the satellites receivers and see if it works.
Good Luck.
Mar 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
