Question about Samsung SyncMaster 710N 17" LCD Monitor
No display on SyncMaster 710N
I bought this display used. I can't get it to display anything from the computer. The monitor passes the self test with the signal cable disconnected from the computer; there is a floating "Check cable" box as there should be. But as soon as I connect the cable to the computer the check cable box goes away. The green pilot light at lower right goes off and on periodically. If I press the menu button on the monitor I get no OSD display, but sometimes I get a graphic box in the upper left corner saying Test Good with a graphic of five small circles with dots in the center, arranged as a row of 3 and a row of 2. None of the other buttons does anything except the power button seems to turn the green pilot light off and on. I'm on a Windows XP system on a laptop with dual display, and I have run other external monitors and projectors off it with no problem. I installed the monitor driver. It seems like the monitor can't read the sync signals from the computer. I'm using a brand new VGA signal cable. The computer can detect that a monitor is connected. The monitor detects when it is connected to the computer or not. Can anyone help?
  • Nicholas Wilson Oct 01, 2008
    I tried the 50 Ohm resistor fix, but it did not fix the problem. I can read some Spanish, and the problem discussed in the dtforum series was not the same as mine. In that case the monitor displayed the message "not optimal resolution." In my case the screen stays blank except a brief message when I press the menu button, as described in my original post. I think the monitor does not read the sync signal coming in from the computer display card.
  • Anonymous Nov 29, 2008
    Can you please tell me the type of this 50 Ohm resistor? Watt?
    New Friend:
I used 2 resistor of 100 ohms (1/8W) to make one of 50 ohms. Like others instruction, just put the 50 ohms resistor between pins 5 and 6 of this chip and the problem is solved.
Posted on Aug 26, 2010
I tried 50oms(2x100oms, 1/4w), it worked for about one day and went back to original situation. Then, I found 4x218oms, 10w resistors, made a 55oms resistor. Now, the monitor works just fine.
Posted on May 12, 2009
  • 537 Answers
I tried soldering a 50 ohm (actually it was a 47 Ohm resistor, 1/4 watt) between pins 5 and 6 on the Novatek IC and that seemed to have fixed the issue. I have been running the monitor for over an hour now with no problems.
Posted on Jan 21, 2009
Microcontroller Novatek firmware is faulted (sorry for my eng)
Posted on Oct 31, 2008
Hi, i had the same problem with a same model monitor, the reason for this problem is a IC (IC200) in the main board on the monitor of course. The fix is cheap and easy, you just have to place a 50 Ohm resistor between pins 5 and 6 of this chip and the problem is solved. Here is the information (in spanish) i found, please give thanks to the autor, not to me!
http://www.dtforum.net/index.php?topic=55304.0;highlight=ic200+resistencia+50
PD: Sorry for my english!
Posted on Sep 27, 2008
  • reywood Oct 02, 2008
    Well, my monitor had the same problem as yours and i fixed with the 50 Ohm resistor, first i installed a 75 Ohm and nothing happens, then i try with a 47 Ohm and was working for a short time and last i try with a 50 Ohm finally it works, but before that, i changed all power supply capacitors and fix all soldering, if that don´t works, well i guess and out of ideas!
I solved the problem by replacing the main IC board. Cost $40 and shipping. The monitor now works perfectly. If I had more time to fool around trying various resistances, or temporarily use a variable resistance for testing, I might have solved it cheaper. However, I'm satisfied.
Part source was www.partstore.com
Samsung ASSY PCB MAIN-STZ;MJ BN94-00689C $39.45 1 $39.45 Sub Total: $39.45 Shipping/Handling: $7.95 Tax: $2.86 GRAND TOTAL: $50.26
Posted on Nov 01, 2008
    Problem Solver:
  • 7 Answers
Hy my monitor (710n) is having half picture scrambled. The lower part of screen is that the upper is ok. Like somebody cut it with the knife. Will the 50ohm tweak work for this?
Posted on Mar 11, 2011
3 Suggested Answers
SOURCE:
  • 54 Answers
SOURCE: NO DISPLAY :(
the resolution setting may have been in inadvertently change to one that your monitor does not support you mentioned that you have another monitor that does work with your computer what i would do is to set the video resolution to the lowest possible setting and the turn off the computer and connect the questionable monitor to your computer and reboot if it does come up then you will be able to make changes and find an appropriate resolution for your monitor
Posted on Dec 28, 2008
  • 65 Answers
SOURCE: my syncmaster 710n is not working.
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Posted on Feb 16, 2010
Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
May 29, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung SyncMaster 710N 17" LCD Monitor Logo
15,348 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
