Question about Olympus Camedia C-5060 Wide Zoom Digital Camera
Open RAW files
How do I open raw files from an Olympus 5060 using Photoshop CS?
  • Anonymous Mar 19, 2014
    psd file encrypted
    Sergeant:
  • 255 Answers
1- Be sure your files from the Olympus are downloaded and stored on your hard drive. 2- Be sure you've updated Photoshop CS' Camera RAW to the latest version: go to http:// www.adobe.com/support/downloads/main.html and click on the OS platform of your choice for Creative Suite, pick the latest Camera Raw plugin to download. Install and you're ready to go. 3- Start up Photoshop CS. You can either use the File Browser to look at the directory where you have put the files from your camera, open them from there, or you can use the File->Open... menu commands to pilot your way there and just open the file you choose explicitly. Camera Raw will start automatically when you pick a .ORF file with either method.
Posted on Sep 13, 2005
I bought a cannon camera EOS 70D, when i use PhotoShop Elements 10, i cannot open the image if the image was taken in RAW.
Hi found a manual for PhotoShop Elements 10 here:
http://help.adobe.com/en_US/photoshopelements/using/photoshopelements_10_help.pdf
It is a pdf file which can be saved to disk for future reference and contains (page 53) a paragraph below:
"Prefer Adobe Camera Raw For Supported Raw Files Ensures that all the supported raw files are opened with Adobe
Camera Raw instead of other software. Select this option if you have added other plug-ins to Plug-Ins folder"
It may be that you have to load the relevant plug-in in order to load these files, or load this plug-in before attempting to load the RAW file.
Hope this helps
Nov 17, 2014 | Cannon Cameras
I have an olympus e410 camera and the images on the memory card are saving as an "ORF" file and will not open in windows. how do i reset my camera to factory settings??
I have a suggestion. ORF is probably "Olympus Raw File" format and you need software to open raw files. See if your camera came with software to do this or use GIMP, PHOTOSHOP, Adobe lightroom. Read your owners manual and change from RAW file to JPG formats. That way, almost any program can open them.
Apr 02, 2011 | Olympus EVOLT E-410 Digital Camera
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
Opening RAW images from Nikon D70 on photoshop
A Photoshop Raw file is a Photoshop PSD file without a header. The header
information must be entered when the file is imported into Photoshop. The
raw format is used import and export bitmap data using a very simple,
uncompressed binary format.
Nov 30, 2008 | Nikon D70s Digital Camera
Re camera raw latest plug in download
Open Photoshop CS3, go to Help and then choose Updates. After a quick check, the Adobe Updater should show you any available updates. Camera RAW 4.3 should be an option if you are not up to date
hope this helps.
Nov 22, 2007 | Adobe Photoshop CS for PC
RAW quality mode option
In the RAW mode, the image is compiled of raw data with no compression and no enhancing settings from the camera such as sharpness, contrast etc. It provides a higher dynamic range with the maximum image quality without being processed, so the user can apply his/her own changes to the file. The file will have a .ORF (Olympus Raw File) extension. It can be read using a supplied PhotoShop Plug-in or the Olympus Camedia 2.5 program.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
How can I use the Adobe Camera Raw plugin after installing Nikon Software?
During the installation of Nikon View or Picture Project, your system is checked for an installed copy of Adobe Photoshop. If a copy with the minimum version is found, Nikon View will install file format filters which will allow Photoshop to open a NEF/RAW file directly (there are other plugins for YCBCR TIFF format from supported cameras). If you have the Adobe Photoshop "Camera Raw" software installed (optional in Photoshop version 7, included in Photoshop version CS) the Nikon file filters will open the file. If you prefer to continue using the Adobe software, find and remove the following plugins: Nikon NEF Plugin (Nikon View) Nikon NEF Plugin LE (Picture Project) After a restart of Adobe Photoshop, the Adobe Photoshop "Camera Raw" plugin will handle the opening of Nikon NEF/RAW format files. Please note that there was an update for Adobe Camera Raw plugin for support of D70 and Coolpix 8700 RAW files, if you encounter difficulty opening raw files from any Nikon product after removal of the Nikon Plugins, please visit the Adobe support site to obtain the appropriate update for the Adobe Camera Raw plugin.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Olympus Camedia C-5060 Wide Zoom Digital Camera Logo
55 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
