Question about Epson R-D1 Digital Camera
How should I clean the camera? - Epson R-D1 Digital Camera
    Master:
  • 542 Answers
To keep your camera operating at its best, you should clean it thoroughly several times a year. Before you perform any maintenance on the camera, be sure to read the Safety Instructions. Then follow these guidelines: * Turn the camera off before cleaning. * Use a clean, dry cloth to keep the camera free of dust. * Do not use harsh or abrasive cleaners. * If necessary, clean the battery contacts with a dry cloth.
Posted on Sep 13, 2005
Do you do Nikon camera sensor cleaning?
No. FixYa only provides online support, and we can't clean your sensor online. Any good camera shop should be able to clean the sensor for you, and/or sell you a sensor cleaning kit.
Apr 26, 2011 | Nikon D3S Body only Digital Camera
Leans moror cleaning
Your camera doesn't have a mirror it uses an electronic viewfinder/LCD, also the lens is fixed so without complete dismantling of the camera the sensor can not be cleaned as with a "conventional" DSLR. I'm going to suggest if you feel the sensor requires cleaning I'd look at the front lens element and clean this with a lens cloth, the LCD screen can be cleaned with a lens cloth as well use a cloth not tissue.
Jan 14, 2011 | Fuji FinePix S7000 Digital Camera
How can I clean the camera's CCD
I strongly advise against disassembling your camera. Unless you really know what you're doing and have the proper tools and realignment equipment, you will surely ruin your camera. What makes you think the sensor needs cleaning?
Jul 06, 2010 | Canon PowerShot G9 Digital Camera
The same few staina appear on various pictures which I have taken on my canon eos 400d. how can i fix this problem? should i take it to the service center?
This usually is caused by dust on the sensor.
Since your camera is equipped with an automatic cleaning system, you can try to run a few cleaning cycles - see section "Automatic Sensor Cleaning" in the user manual.
If this doesn't help, the next thing you can try is to blow the dust off, using a blower bulb, as shown in the first part of this video:
To open the shutter for manual cleaning, you use the "Sensor cleaning: Manual" function of your camera.
If you are unable to remove all the dust with the blower, I would recommend performing a wet cleaning, as shown in the first video on this page:
http://www.photosol.com/demolink.htm
If you want to do this yourself, order the proper cleaning kit for your camera. Use a professional product, recommended for use with your camera, don't make any experiments!
Alternatively (may be the better idea, actually), have the sensor cleaned in a camera repair shop.
For further information just google "DSLR sensor cleaning"...
Mar 10, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
At switch on, the camera comes on, lens comes out, and then immediately goes back in and camera switches off. Battery fully charged. Works fine when in the mode where you connect to a PC.
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 02, 2009 | Kodak EasyShare M863 Digital Camera
Kodak Z760 easy share camera. The camera will not turn on, lens does not come out. Battery is fully charged.
For this problem try the following:
  • Try removing the memory and the battery
  • Try using the camera w/o the memory card
  • If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Sep 01, 2009 | Kodak EasyShare Z760 Digital Camera
My camera lens is stuck in the closed position. When I turn the camera on, the motor runs, but nothing happens. I accidentally picked the z740 camera when posting the proplem originally, but the z700 is...
If you've dropped the camera you may have damaged the lens housing - which will require professional repair, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 31, 2009 | Kodak EasyShare Z700 Digital Camera
Hello Kitty KT7009 camera won't charge!
It could be something more serious, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 29, 2009 | HP Photosmart M425 Digital Camera
My camera doesn't turn on
Aug 25, 2009 | Kodak EasyShare C613 Digital Camera
Won't turn on
You can try to clean it out..you do this by following these steps: 1. Clean the inside of your camera by opening the back and then blowing the dust out with a can of compressed air, or with a bulb tool that blows air when you squeeze. 2. Clean the lens by blowing any dust off with compressed air. Use a special lens cleaner and lens cloth to thoroughly clean the surface. 3. Wet a cloth and wring out as much water as possible. Use this cloth to clean dirt off the camera casing, making sure no water seeps into the camera's interior. 4. Use a dry soft-bristle toothbrush to clean out the crevices of your camera's casing. 5. Rub dirty battery contacts with a pencil eraser. Although, this is not a common problem..if cleaning it out does not work you are better off going back to the store and either returning this item or demanding a repair service.
Sep 17, 2006 | Nikon COOLPIX L4 Digital Camera
Epson R-D1 Digital Camera Logo
55 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
