Have an emerson EWT 19S2 model. want to hook up dvd
How would i find an imput source or tv/video button
  • dufay Dec 07, 2008
    looks like you need the remote to switch tv/video
3 Suggested Answers
  • 104 Answers
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Posted on Feb 12, 2009
  • 5 Answers
SOURCE: Admiral TV model GRD15272 video/dvd
Using the buttons on the TV, go to the setup menu, and scroll to "edit channels" by pressing "setup" button until "edit channels" is highlighted. Then, using the channel up/down buttons, go to channel 91 and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Posted on May 30, 2010
How to hook up a sony dvd player to a emerson tv
Need to know the model numbers of the DVD player and the TV before any sort of help can be given.
May 20, 2012 | Emerson Televison & Video
How to connect a DVD player and watch a movie on a EWF2004 ?
on the front and on the back of the TV it has a set of tulip jacks a yellow one for
video and either a white or red one for audio. Take a set of RCA cables and hook them
from the DVD to the TV via the colors yellow for video red/white for sound. For this TV
I believe you will need to go throught the channels until you find composite/AUX1 or composite/AUX2 which the DVD will be assigned to. If the DVD player is on and functioning you should get a picture. If you dont get a picture and you get fuzz and buzzing on these channels you have the video and sound reversed. Some models may have a source button on the front of the TV or on the remote. If this is the case use the source button to get to the Composite/AUX channel.
May 06, 2011 | Emerson EWF2004 20" TV
I dont have the remote to the tv but i wanna hook up the dvd player how do i do that with out the remote
Hello, when remote control is not available, there are two options, first look if there is a source selector button, usually located in front of the TV. Next to the buttons that change the volume and chennels, the name of the button can be a source, AV, or video. A second approach is to enter the main menu is also located in front of the TV. See if it is possible to set one up direct connections by default. Unfortunately there are models that without remote control can not be transferred to another source. In any case you can always adapt a universal remote. I hope it was helpful! Please come back to me if you require further guidance.
Feb 27, 2011 | Emerson SpongeBob SquarePants TV
We used rca cables to hook up the ps3 to tv and its not showing on any channels
Are you flipping thru the channels on the remote like you would for tv?
Usually what you have to do is look for a button that source or imput on your tv or controller for the Tv. that will cycle thru available imputs like HDMI 1, Cable, Component 1, RCA etc. until you find it. make sure the PS3 is on as well.
If this doesnt solve it you may have a faulty cable, you may want to try a new one if you have and see if that solves the problem, or use the same RCA cable to hook up a dvd player or other device, if it doesnt work on that device you know the problem.
Hope this helps
Jan 26, 2011 | Video Game Consoles & Games
I cannot seems to get to the imput channels to play a dvd
on remote should be under video,,or input,,,on front of tv ,,i think input,,,or source,,it will come up 2 video1,,,video2 and so on
Nov 03, 2010 | Emerson EWF2703 27" TV
I NEED TO KNOW HOW TO SWITCH THE TV TO DVD MODE ON THE TV
DEPENDING ON MODEL PRESS SOURCE BUTTON SCROLL DOWN TO DVD THEN PRESS SOURCE BUTTON OR TV/DVD IF SET HAS ONE
Aug 25, 2010 | Emerson Televison & Video
How can I hook up my PS3 to an Emerson TV? There is not a place in the back for the jacks to plug in to. Just a place for an antenna. Model: EWT 19B3, AC 120V 60Hz 72w.
This is an older television. You need an converter box. These are generally called RF modulators and take composite video (3 RCA plugs - 1 video and 2 audio) to coax. If you want to use component video out from your PS3, you may need a component to composite video converter as well. For an example, see http://www.svideo.com/ypbpr2svideo.html. Unfortunately, you will get signal loss with the conversion.
I hope this helps.
(Walmart and RadioShack have carried RF modulators in the past. RadioShack probably still does.)
Jul 21, 2010 | Emerson EWF2004 20" TV
May 12, 2010 | Emerson Televison & Video
I have a 27 inch emerson tv and no remote, all i want to do with this is set up DVD player but there is no input button on the TV any Ideas
If no imput buttons on TV try using up-down chanels on TV.You should either find an AUX or other imput.Plug the A/V wires in and turn on the DVD player first.Good luck
Sep 05, 2009 | Televison & Video
Hooking dvd player to tv
check if your dvd video output is switched to the svideo or RGB and make sure it is switched to the output youare connecting video cable .
Dec 31, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
