Question about Epson R-D1 Digital Camera
Does the camera have parallax correction? - Epson R-D1 Digital Camera
    Master:
  • 542 Answers
The Epson R-D1 uses automatic parallax correction. Just set the frame selector lever to match the focal length of the lens being used to automatically correct parallax.
Posted on Sep 13, 2005
What are the differences between viewfinder and rangefinder cameras?
A rangefinder is a camera that has a rangefinder mechanism. This is a device that measures subject distance. Through this device, you see two images. When the two images coincide through moving the dial, the correct distance is displayed. On older cameras, this was a separate device and one must transfer this to the lens.
Now they are built into the viewfinder. You have different viewfinders for different focal lengths (zoom lenses are difficult, as a result).
A viewfinder is what the photographer looks through to compose, and in many cases to focus, the picture. Most viewfinders are separate, and suffer parallax, while the single-lens reflex camera lets the viewfinder use the main optical system.
Apr 10, 2018 | Cameras
7155 Parallax Power supply 12 volt side problems, all fuses and wiring in good working order.
http://d163axztg8am2h.cloudfront.net/static/doc/b5/84/8f1a1586e9cb74379e85d9136830.pdf
Dec 12, 2017 | Parallax Power Supply PARALLAX POWER 7155...
Why does the cooling fan run all the time ?
I suggest you call Parallax Power Supply
100 W 11
th
St. Suite 100
Anderson, IN 46016
Ph: (800) 443-4859 Fax: 765-608-5235
Jul 02, 2014 | Parallax Power Supply Parallax 7300 Series...
Battery is installed properly and keeps blowing 40 amp fuse on the out put side.
Hi there, Ive had the same problem that came from a worn out wire that was toucing, this may be the problem.
May 26, 2014 | Parallax Power Supply PARALLAX POWER 7465...
What are adjustments on front of scope
For parallax error correction at different distances
Mar 16, 2014 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
When i take a picture although i centralise an object in the centre if the screen, when the shot is taken it moves downwards and off centre? why is this?
I presume that you're using the optical viewfinder and taking close-up photos.
If so, then your camera is fine but you are making a simple mistake. What's happening is called "parallax error". The viewfinder lens does not see exactly the same view as the camera lens because it's slightly higher and off to one side. For most subjects greater than a few feet away the error is insignificant, but for close ups it becomes a problem. Many optical viewfinders of your type will include framing lines. These show the approximate image which will be taken at distances of more than a few feet, and may have a second set of stubby lines to show where the image will be cut off during close-ups.
Your fix is to simply be aware of parallax error and allow for it when composing your images.
I hope that this has answered your question; if so then please take a moment to rate my reply. If it hasn't then please add a comment with any additional detail you think will help and I'll try again when I'm next online.
Mar 10, 2011 | Canon PowerShot A300 Digital Camera
I have a weaver k-8 scope with adj. rings on front bezel ??????
the front ring is for adjusting point of impact at a given range,,,its called a "parallax ajustment" it corrects for the scopes inaccuracies over its full range say from 10 yds to 100 yds there a bit of a pain on a hunting rifle as you need to focus them every time and that slows down your shooting, when only a snap shot will get the kill you cant wate to mess about focusing the darm scope so i never use them on my rifles,,unless im target shooing,, or im snipping when i have time to take my shot,,,
(a head shot only!) only a parallax scope is spot on aim from 10yds to infinity
Nov 18, 2009 | Weaver Optics
A Question
What you are seeing is normal behavior for a rangefinder camera. The problem is called parallax error and it occurs with any camera in which the viewfinder is physically offset from the image sensor. As you may have noticed, the problem becomes worse as the camera is brought closer to the subject. You can either learn how to compensate for this, by rotating the camera upward slightly, or by using the LCD display to frame the image when you are closer than approximately 10 feet from the subject. The markings in the viewfinder may help you to judge how much compensation is necessary.
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Epson R-D1 Digital Camera Logo
93 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
