Question about HP OfficeJet 6210 All-In-One InkJet Printer
Fax and copy problem
WHEN I PLACE A SHEET TO FAX OR COPY IT LOADS THE PAPER AND THE BAR ON THE SCREEN COMES UP AND THEN IT JUST STALLS AND DOESN'T WORK. TURNING IT OFF IS THE ONLY WAY TO STOP IT.
IT STILL FAXES DIRECT FROM THE COMPUTER AND PRINTING IS NO PROBLEM.
  • TommyBr Sep 10, 2008
    My 6210 has the same problem with copy, fax, or scan. It doesn't matter if the source document is placed into the feeder or directly on the glass. It also gets the same results using HP Director or the buttons on the all-in-one. When trying to copy/scan/fax the printer display will read Scanning or Coying, etc. and the bar will begin on the left of the display. That's all that happens. No errors. I've waited 10 minutes with nothing more happening. Pressing the Cancel button will not clear the display. Powering Off will send a blank sheet of paper to the printer output. Powering back on shows no errors on the printer display. The display appears as if the printer is fine.
  • 234 Answers
Does the All-In-One make a loud noise and then stalls.
If it does then it should also give a message as Scanner Failure.
Take out both the cartidges from the All-In-One and unplug the power cable directly from the All-In-One and move the carriage (carriage is the on which hold the cartridge) Too and Fro unitill you feel it is moving freely, Then insert the ink cartridges and close the access door, And plug the cable directly to wall outlet without surg protector, and before connecting the power cable to the printer press and hold the # and No 6 keys, without releasing the keys insert the power cord and after you see a window which says semiful reset you can release the keys.
And in case the screen goes blank then release the keys and turn the power On, on the All-In-One.
Good Luck.
Posted on Sep 02, 2008
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Sends Blank
select copy instead and what do you get.
if nothing then the ccd bar is bad.
Jun 04, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Receive a black copy
scanner problem. if you receive faxes that are good. the scanner is used when you copy or send. Lawrence
Feb 26, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
Feb 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Samsung Fax/phone model 1600
You could try opening the feeder and clean the gray rollers with mentholated spirits and see how that helps as it just maybe the rollers are slipping slightly.
Once you have done the above take out all of the paper from the back feed and using one sheet blot the leading edge with some spirit and place back into the machine (The back of it) then try coping something there will be a paper jam and do this a couple of times. Once you have done this wipe the area dry put new paper in and then try doing a copy and the paper should feed perfectly now and the test will come when fax comes in.
I do hope this helps you
Thanks J
Oct 30, 2007 | Samsung SF-4500 Plain Paper Thermal Fax
Copying
you place the paper in the same place as if you were faxing and the paper it's printer in the rear most carrier, but one press of the button indicates you want one copy, pressing it again should then do one copy.
Aug 11, 2007 | Brother FAX-575 Plain Paper Thermal
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP OfficeJet 6210 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
