Question about Marvel (6SBARBSG) Wine Cooler
Marvel model 61WC Wine cooler
My Marvel is 7 years old and compressor stopped working. Does anyone know how to fix instead of spending $1500 for a new one that will not even match the one sitting next to it?
  • 1 more comment
  • loveovergold Sep 01, 2008
    I have power and light and thermostat set as cold as it will go. I have two and the other one is fine. Where should I start?
    I will open it up tomorrow and see where poer is going and then get back to you. Are parts available for this model or are they generic?
  • winelover47 Dec 13, 2008
    our light is on, but the marvel wine refrigerator no longer gets cool.. any solutions beside buying a new one??
  • 101 Answers
If the unit was made after 2000, there is a solid state control in the back that you can test. If it was made before then, it will have capillary tube style thermsotat that you can test.
Made after 2000:
First, pull the unit out to access the back lower area and disconnect the power. Remove the lower backing to access the mechanical area. There will be 2-inch square back box with seven terminals and 4 dip switches. Disconnect the red and black wires from terminals # 3 and 2 respectively and connect them together (this bypasses the control). Plug the unit in...if it runs you need a part of or all parts of the control.
Made before 2000. With power disconnected, remove the front grill to get access to the thermostate (usually on the right side). It will have up to three wires connected to it and a sensing line. Leave the green (ground) wire as is (if connected), disconnect the other two wires and connect them together or run a jumper. Plug the unit in...if it runs then you need a new thermostat (only one part).
If the compressor does not run but the condenser fan does...something is wrong with the compressor.
You can also call the factory at 800-428-6644 and ask for technical assistance. They can assist you with further troubleshooting and/or finding a servicer near you. They should still have parts to repair that unit.
Posted on Sep 14, 2009
  • coalie Sep 05, 2010
    Hi...I found this post which is about a year old referring to a problem with a Marvel fridge (power to light, but compressor won't turn on):
    This described my problem perfectly, thanks! So I need a new thermostat. My question is, do I have to unsolder the sensing line and solder in the new one? I can't see how to disconnect the thermostat without unsoldering it. At the back end, it goes in behind the insulation which is glued in.
    David Levy
  • 725 Answers
First do you have power to the compressor? if not it could be a control... if you do it could be a relay...let me know and I can help
Posted on Sep 01, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 01, 2008
    if you have a mulimeter check for power to the relay on the compressor...
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
My ewave made by magic chef model mcwc 30 mcg wine cooler is 5 years old, it just stopped working. Is it worth fixing or spend over $300 to buy a new one?
it could be the ptc the left of the compressor.if its clicking its the problem.around $27.00 fix at #1206838 the part is behind the plastic cover with 1 screw left of comp.the top part with 1 wire will wiggle off to the left.
Mar 11, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
I have a client with a ten year old Marvel 24'' built in wine cooler, and the weater stripping is falling off. I can not find a model # anywhere. Derek
Dear Dereck,
Does your client have any idea how old the unit is? What do you mean by "weather stripping"? If you need a door gasket, all their 24" wide units (except ADA height) use the same gaskets. Part number 42241280 for the white and 42243906 for the black. You can order direct from the factory at 800-223-3900 (they are in EST in Michigan) should you need something else, describe the unit to their customer service personnel and they should be able to assist you. (Ask for Tim or Ron) - Subdriver
Jan 27, 2010 | Marvel 61WC Wine Cooler
My marvel wine cooler is 9 years old and no longer runs. The light works but nothing else runs. Might this be the thermostat? iif so where would I ge a replacement and would would it cost?
This could very well be the thermostat (pre-2000) or part of the temperature control system (2000 to 2009) which has three parts: The thermsitor (usually the culprit), the potentiometer (connected the the control dial) or the control board. Call the factory at 800-223-3900 with your serial number (to identify which control it uses) and you can buy the part direct from them. The control kit is about $150.00, the old style thermostat about $100,00 and if it is just the thermsistor, it's about $50.00 (I haven't checked their prices in awhile)
Jan 18, 2010 | Marvel 61WC Wine Cooler
Humidity and temp control not working.unit is 12yr old
The 61WC does not have humidity control in it unless it was added after the factory. The old style mechanical control is still available from the factory at 800-223-3900 PN 42241702 (ask them to double check my memory on the part number)
Jan 06, 2010 | Marvel 61WC Wine Cooler
Marvel 61wc temperature will not go below 67 degrees F. Ice has accumulated on the back wall on the coil.
The 61 WC is a cycle defrost/plate sensing control. If your unit was manufactured before 2001 it will use an electric/mechancal thermostat that has a capillary tube that senses temperature. If it was made after, it will use a solid state control box that has a "thermsitor" sensing temperature and a potentiometer for user input (OFF through 7). If the unit runs constantly, and does not reach desired is low on freon due to a leak. This will be evidenced by ice build-up where the freon first enters the evaporator plate and no where else. You will have to have a technician fix the leak and recharge the unit. Don't wait to long to ge this corrected. If the unit runs too long with a low charge it could draw air and contaminants into the system and the compressor will get damaged.
I hope this helps.
Sep 09, 2009 | Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Dec 02, 2007 | Marvel 61WC Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Marvel (6SBARBSG) Wine Cooler Logo
493 people viewed this question
Top Marvel Furniture Experts
Sal De
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
