Frigidaire Window Air conditioner
Needing white plastic control knobs for my window unit.
Cant find model number or BTU but I think it is 12,000 BTU. Control knobs are located on the left of the unit and are in an open area with no door that closes in front of the knobs. Uses replaceable filters not the washable permanent type. Hope this helps figure out which model I have
Both control knobs are identical in size 1/1/2 in diameter
If you can direct me to a site that sells them cheap or any other info I would be very grateful
Thanks
kstfas
  • 75 Answers
SOURCE: 1990's Emerson Quiet Kool window air conditioner
Hi, It opens a flap that allows fresh outside air to come in. The opening it screen covered on most units so no insects get in. To get the most cooling it is best to leave it closed. If you want fresher air, open it. Please rate my suggestion if it has helped. Thank you and, Have a good day. kstfas
Posted on Sep 07, 2007
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
SOURCE: Error code A5 on Frigidaire
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Posted on Jun 05, 2009
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    User guide or manual for frigidare 12,000 Btu window air condition model number lra127ct1
    Here is a link to the manual. http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020211a1417en.pdf
    If the link does not work leave me your email address and I can send you a copy of the pdf file.
    Sep 13, 2013 | Heating & Cooling
    What is the btu of this model.m7q08f2a.
    Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
    Sincerely,
    Shastalaker7
    A/C, & Heating Contractor
    Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
    We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
    Here is a tip about troubleshooting your air conditioner...
    There are many things that can cause your air conditioner not to cool…
    Air Conditioner Trouble - Review the Possibilities
    heatman101
    Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
    Frigidaire window air condition unit
    Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
    Apr 24, 2010 | Frigidaire FAC126P1 wall/window Air...
    Error code A5 on Frigidaire 12,000 btu air conditioner
    Jun 11, 2008 | Heating & Cooling
    Thermostat set to low.
    If your A/C has a digital control panel no screw driver is necessary to reset the temperature.
    http://www.frigidaire.com/products/
    resultspage.asp?strmodel=FAA065P7
    The above URL will take you to the site to download the owners manual for your model number stated.
    May 11, 2008 | Frigidaire Compact Air Conditioner
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
