Question about Gigabyte Computers & Internet
My motherboard can;t detect my harddisk.....
Im having an amd athlon 2800+ socket 754.motherboard:gak8vm800m......harddisk:s2 samsung(hd161hj) {160gb/7200rpm/8m} 512mb ram ddr2...bios by energy star...my problem;s even after installing the sata drivers i jsucant isntall windows xp on my hard disk which i jus bought a few days ago....coz it says set up couldn;t detect hard disk.....also i heard that sata 2 is back ward compatible...is it correct...or is it just my motherboard that;s giving me the problem....has worked perfeclt fine wiht sata1...(by sata1 i m referring to the one operating at 1.5gb/s).......plz hlep me out...have been ova a month......since my system has been down.....
    President:
  • 2,351 Answers
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Posted on Sep 02, 2008
  • 781 Answers
I believe when installing from windows disk it asks you to press F6 if you have SATA disks so it can load the drivers for them
Try it and see how you go
Posted on Sep 01, 2008
My computer is one hdd I'm another hdd is connect in my pc
Posted on Sep 18, 2008
    Genius:
  • 1,027 Answers
The motherboard may not be SATA 2 compatible - restore it back to the slower speed. Most of the new drives have a jumper that selects the drive speed (ON for slow SATA, off for fast)
Motherboard need for ada3000aep4ax processor
http://cgi.ebay.com/Emachines-MotherBoard-AS-IS-MODEL-W3107-SOCKET-754-/200635905747?pt=Motherboards&hash=item2eb6d4f6d3
http://www.phoenixdirecttech.com/products/1529-asrock-k8upgrade-nf3-socket-754-motherboard.aspx
Aug 04, 2011 | AMD Athlon 64 Processor 3000+* (2.0GHz)...
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
I have AMD Athlon(tm) 2800 64 Processor 2800+ 1.81 Ghz 1GB RAM I want to upgrade it to Latest AMD 64.Please let me know what is to be done?
There is a full list of AMD 64 processors at http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors.
The Socket of your CPU is 754 which means that the highest you can go is to a 3400+ at 2.4GHz.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 13, 2010 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
IS MCP61S THE SAME AS NF61S MICRO 754
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
Computers & Internet Logo
2,398 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
