Question about Frigidaire Kitchen Ranges
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
I have a Frigidaire Ellite stove with and electronic clock, how do I set the clocl
Posted on Jan 17, 2013
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Posted on Aug 19, 2009
Where do i find the unlock lever on a frigitare stove
Spell 'Frigidaire' correctly and Google
Frigidaire make model manual
It is usually a combination of two buttons pressed or one button pressed and held for 5 seconds to unlock the hob.
If it is the oven that is locked after a clean cycle. Unplug or flip the breaker from 20 seconds. It is an electronic lock.
Jan 20, 2018 | Ovens
My kenmore oven model c970-692622 is lock.what is the step of unlock.
Select "clean" function and observe whether or not the lock attempts to reset itself, if no movement occurs- you will need a lock latch assembly. If the latch just circles round and round, then you need one of the microswitches in the assembly... Frigidaire Range Stove Oven Micro Switch 5304440026
Jul 12, 2016 | Kenmore Ovens
I have a Frigidaire elite stove model RJB646EW . The electronic board is flashing. I shut the breaker off and turned it back on after an hour and it still flashes
Hey friend, thank you for your inquiry!
Based off the information you have provided the board on your Frigidaire Elite stove is flashing. I was unable to locate any additional information on troubleshooting for your model. Once an appliance has been produced manufacturers will no longer carry information after it is ten years old. I would recommend consulting with a professional technician for proper diagnosis and repair. Best of luck! -Matt
Mar 01, 2015 | Frigidaire Kitchen Ranges
How to unlock the door when not cleaning by itself
Thank you for your post, wilma jones!
I understand that the door on your Frigidaire range is not unlocking. I see that you have attempted several troubleshooting steps and the door is still locked. From what you have described it sounds like a possible faulty door switch or wiring harness. I would recommend having a professional technician out to properly diagnosis your range this will help to avoid any unnecessary part purchases. Best of luck! -Matt
Dec 24, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
I have a Frigidaire Professional Series Stove. My red lock light will not go off. When I came down stairs it was on. I locked it & unlocked it and it's still on and my stove will not come on.
I looked up your model number and I would suspect a faulty door lock latch motor switch, part # 316464301.
It can be located my removing the back panel of the stove.
Aug 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I have an older frigidaire self cleaning stove and i cannot get it to unlock for some reason it is stuck on lock mode the knob is wore out so it is a little hard to see where i need to get it
have you tried to unplug the stove and see if when you plug it back in it will allow you to unlock the door? you may have a door lock solenoid burnt out on it as well, in which case you will need to replace the door lock mechanism.
Oct 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Nov 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
May 10, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
855 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
