Question about Canon PowerShot A450 Digital Camera
Connon camera my camera says card locked each time i turnit on and it sucks cause now i might have to get new card unless you no a different way to fix it with out it costing a dime
  • Canon Master
  • 4,738 Answers
Remove the SD memory card from the camera. Slide the tiny slide switch on the side of card to the other "unlocked" position. Reinsert the card in the camera. That should do it. No charge :-)
Posted on Sep 02, 2008
Why is it displaying "no SD" message?
yes, unless two different sd cards could go bad at same time. Bummer.
Aug 30, 2015 | Cameras
My camera says card locked but I have no memory card in the camera. I can not take any pictures
The camera won't take photos without a card unless that model has a menu setting to allow that option (though nothing is stored). Put a different card in the camera and format it. If it doesn't see the card try formatted it first in the computer and then format it in the camera before you try shooting.
Oct 18, 2014 | Samsung NV10 Digital Camera
Quantaray lens
You did not mention which lens. Some Canon digital cameras will only take EFS lens, others take both EF and EFS. Also there are other types of lens mounts made by Canon.
Cordially,
Jan 01, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Quantaray 70~210 Lens
If your lens is a EF mount and your digital can take EF lens the answer is yes.
Cordially,
HP camera R707
Even after you did format these cards in the PC, you better chose to format the cards in the camera you want to use it.
And if you have checked the cards on the memory card, please also check the contacts in the camera.
Dec 30, 2013 | HP Photosmart R707 Digital Camera
Canon g9 just started getting card locked error. I checked, the card is not locked - also tried different cards. It works sometimes. Tried to reset the settings and received "busy" message.
Check the right strap lug and see if it is loose. It is a well know problem with the G9 that the screws that hold it onto the top cover come lose and fall into the camera, causing many different problems is they short out parts of the circuit
Feb 17, 2013 | Canon PowerShot G9 Digital Camera
Memory cards are locked but the card is not locked
It's unusual that an A95 would report "card locked" as it uses a compact flash card which is incapable of being locked. Please verify the model of your camera, and the card that it uses.
In the mean time, I'll assume that actually own a different camera that uses SD cards. If so, please see this link for troubleshooting tips for SD card locked problems.
But if you indeed own an A95 with compact flash, the problem may possibly be caused by bent flash card pins inside the camera card slot (take a look inside using a flashlight). If bent pins are found, then see this link for a possible home fix.
Apr 15, 2010 | Canon PowerShot A95 Digital Camera
When i turn the camera on it says memory ard error
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 01, 2010 | Optics
Memory card won't format on Kodak Easy Share camera
Make sure that your memory stick is not set on not to write. There is a white slide on them showing a lock and unlock symbol. Put it on the unlock symbol.
Oct 10, 2009 | Kodak EasyShare C315 Digital Camera
Camera turns off
1. Try the camera with a different CF card. 2. Try the camera with a different battery. Defective components don't always fail in expected ways. The battery might have enough power to "sometimes" operate some functions but not consistently. The CF card may be malfunctioning is some way that draws too much power from the camera & at times causes it to "lock-up" or shut down. If you don't have another battery or CF to try, you may be able to bring your camera into a camera store where they may have & let you try 1 of each on your camera to see if it fixes the problem. They may do this in the hopes of selling you either a new battery, CF or camera depending on which proves defective.
Jan 07, 2006 | Fuji FinePix A605 Digital Camera
Canon PowerShot A450 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
