They do make a tool for removing these inner C.V. joints, it is avalible at Car Quest Auto Parts.
The problem is the joint has come loose from the inner housing and I can not get a slide hammer on it. This is the driver side. Went to remove the passenger side so I could get a punch and try to knock it out but it also came apart and I cannot get it out know. If anyone has any ideas it would be greatly appreciated. E-Mail address is [email protected] Need info really bad. Thanks.
Give up its impossible
The joint is held in with a spring clip. Try a brass punch and a hammer. Hit it on the metal part of the joint,forcing it away from the transmission.Be careful not to hit it too hard, or slip off and hit the boot.Spray the shaft into the trans with WD40 or an equivalent.Good Luck.
Is it on the driver side or the passenger side? when i have a little trouble i use a slide hammer. put the nut on the shaft and use the 3 jaw attachment of a slide hammer this will help you.
My axle came apart know I cannot get the inner part out of the Trans.
